Tools?
  • goatman
    • Jun 2004
    • 151
    Tools?
    Other than the obvious hoist, are there any specialty tools need for pulling the engine out of a Lumina Z34?
    1993 Lumina Z34 - Broke Yet Again
    What the flip Uncle Rico!?!
  • Anonymous
    Beer. Lots.
    Other than that, not really. it is pretty standard believe it or not.
    • goatman
      • Jun 2004
      • 151
      Am I correct in saying that the drive axles need to come out? What is involved with this?
        • 13531
        Yes, you need to pop those out. Remove the brakes and rotors, and then 4 15mm bolts holding the hub in place. You can pull the axles through the strut assembly with the hub attached. Prybar or something of that sort to get behind the axle to pop it out is all it takes. Some are easier to do than others. You will need to turn the wheel all the way to 1 side in order to get them to clear the sway bar, but thats about it for finally getting them out.
        • goatman
          • Jun 2004
          • 151
          OK, thanks a lot. I was flippin through the Haynes manual, and they make it look/sound like brain surgery
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            also when you pull it make sure the passenger side is quite a bit higher than the driver's side or you will have a hard time.
            • Dave
              • Nov 2003
              • 222
              a sawsall, and a blow-torch. those two tools will get ANY engine out.
              --Dave.
              Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
                • 13531
                yeah, but I think he wants to use the car afterwards:P
                • Dave
                  • Nov 2003
                  • 222
                  well then, a all you need is a good wire-feed welder ... helpful hint - use flux core wire so you don't have to pay for a ton of argon...
                  --Dave.
                  • goatman
                    • Jun 2004
                    • 151
                    On these axles, once the four bolts on the hub are gone, they should just pull right out? Or is there a clip or something that holds them in the tranny?
                    • goatman
                      • Jun 2004
                      • 151
                      Never mind, just needed to be a little creative with that pry bar. . .
                      • dohcfiend
                        King Chalupa
                        • Jan 2004
                        • 2351
                        u could just pop the cv joints out of the tranny but you have to re-install the band clamps and they are a pain.
                        to do that pull back the cv boots and jack up the engine until they are almost out then pop them out with a straight screwdriver.
                        • goatman
                          • Jun 2004
                          • 151
                          Well, the axels are out, the motors commin out tomorrow nite
                          • goatman
                            • Jun 2004
                            • 151
                            Motor is out! Got a little hairy at the end though. Had the leveler on the hoist, then ran out of room in the garage, so we set the engine back down on the front part of the frame that holds the fenders together, and ran a loop of braided steel cable through it. Then, as we got it going back up, SNAP! the part of the alum. cover that the PS pump bolts to snapped right off. I thought the whole thing was gonna come down. But, now its out.
