How to tell if car came with keyless entry?
  • Toofastgtp
    • Oct 2004
    • 57
    I got a 94 GTP with basicly all the options
    Sunroof, Hud, steering wheel controls, 2nd gear start, B4U
    Is there a way to tell if car has the system?
    -2000 GTP - 332/426
    -94 GTP - Stock, But needs new:
    Door, Steeringwheel, fender, windshield and window for new door, and power steering line.
  • DrRodey
    • Nov 2004
    • 76
    There should be a little black box under the drivers side of the dash. That would be the recieving unit for the signal from the remotes. If thats there I would say it probably came with keyless entry.
    Dan
    92 GP GTP 3.4DOHC 5spd
    88 Fiero Formula CONVERTIBLE 3.4DOHC 5spd
    84 Fiero T-Top 3.4DOHC 5spd
    There seems to be a pattern there.
    • grandprixgtp_91
      • Nov 2003
      • 758
      if im not mistaken the back box is in the rear, under the panel that covers the rear speakers, it says trw on it.
      Jake
      • 93RegalGS
        • Apr 2004
        • 20
        if you have this wire by your attenna you have keyless entry.
        -Sean
        99 Regal GS L67 / 4T65E-HD
        91 Cutlass Supreme International - 3.4 DOHC/ 5 Speed - SOLD - I still love LQ1s!
          • 13513
          I thought it was under the rear as well, close to the antennae so you can ground the wire to set the key fobs.
          • DrRodey
            • Nov 2004
            • 76
            So if it's in the back, what is the little black box under my dash that's connected in with the ignition lockout, lights, and God knows what else, it has wires going everywhere. It's a factory GM box, not an aftermarket alarm or keyless entry.
            Dan
              • 13513
              got a pic?
              • 93RegalGS
                • Apr 2004
                • 20
                That box Is probably the Chime box.
                -Sean
                • DrRodey
                  • Nov 2004
                  • 76
                  Sorry won't be able to get a pic until next week, never home anymore between class/work/internships/etc.
                  Chime box does kinda make sence thought since it is wired to from what I can tell, just about everything that makes noise. Just looks a heck of a lot like about every other remote start/keyless entry box i've ever seen. Thanks.
                  Dan.
                  • 93RegalGS
                    • Apr 2004
                    • 20
                    Yeah, the chime box has a few wires going into it.
                    Here's another way to check if you have keyless entry. Look at the Serive Parts Identification Label (probably on the spare tire cover) And see if you have the RPO code "AUO" if you have it your car came with keyless entry.
                    Hope that helps.
                    -Sean
