update on dead 3.4lt
  • jimmy91444
    • Nov 2003
    • 21
    machine shop are able to bore the cylinder and install a sleeve, this is being done.
    i found a head for $225.
    3 Piston are $45 each. compare to dealer at$265 for 1.
    Rings are at around $200 a set.
    1 Connecting rod (dealer item only since none at the scrap yard)is $140.
    This is going to be a expensive rebuilt. So if any of you guy s have parts for sale at a decent price + shipping that might be cheeper than buying new, specialy the connecting rod at $140.(That is #2 piston) but i don t think it make a difference. i ll keep you updated as it progress.
    91 cutlas int, 3.4lt alive again
    89 cutlas int 2.8lt.
  • Anonymous
    Contact Ben (Sappy). Hes got a garage full of parts.
      Also, with some machine work, Chevy small block v8 rods can be used. Ben can fill you in more on this too.
      • Cliff8928
        • 532
        Won't any V6/60 rod work just the same, they never changed them, did they?
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
          They should, but I think the LQ1 rods are the strongest, but don't quote me on that, I don't know for a fact. But if you are wanting something stronger then stock DOHC rods, you could shot peen the stockers, or go with machined small block rods. When I do a performance rebuild, you can bet I am going to go with the small block rods, huge aftermarket.
            • 13534
            The rods are the same, but the DOHC castings look nicer compared to the 3.4 pushrod RWD rods. I don't know about them being stronger, but its not likely. Deburred, polished, and shotpeened they should be good enough for any NA build up minus trying to go super high RPM. 8k might be ok, 9k, I won't try on stock redone rods.
            • GPXSS
              • 588
              i have a few rods laying around, they are all the same for all years and engines.
              hows $20 sound? send me an Email if you want it, GPXSS@aol.com
              I modify stuff
                • 13534
                I sent him a PM with no reply.
                • jimmy91444
                  • Nov 2003
                  • 21
                  Sorry Ben i did not received your pm
                  Gpxss Thank s . I am in contact with a guy that send me an e mail. He has some rod frm a 3.4 . if that don t work i will contact you
                  thank s Everybody.
                    • 13534
                    Is that cylinder head brand new for 225? I have heads here that I would sell for much less than that but they are used. I also have a set of connecting rods and a connecting rod that is good with a good piston still attached. I may even have 6 good pistons/rods as part of a motor but I would have to take them out to verify.
                    Let me know if you still need all those parts, cause im sure I can save you a great deal of cash on some of them.
                    Thats what I sent in the PM.
                    • jimmy91444
                      • Nov 2003
                      • 21
                      Ben you have P,M.
