Compression numbers?THOUGHTS???
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    i looked at a replacement motor a few days ago and i came back today and did a compression check.
    here are the numbers:
    6=150
    4=150
    2=120
    5=150
    3=135
    1=125
    looks like the lowest one is about 20% different than the highest. should i snatch it up or keep looking?
  • BMFH
    • Jul 2004
    • 42
    RE: Compression numbers?THOUGHTS???
    Hello All
    A cylinder leak down test will tell you more about how good of shape everything is, it is a time consuming process, but you will know exactly where and how much compression is being lost by listening for excaping air and you will have a gage reading showing the percentage of compression lost.
    Hope this helps make a better decision.
    John
    • blk92z34getrag
      • 515
      That is pretty low that means you should definately leak down the cylinders. If 1 and 3 are both lower you might have head or block problems...
      Don't forget to listen for hissing out of anywhere (oil fill cap, spark plug holes, intake and exhaust...).
      EDIT: Sorry for practically repeating what was already said... I'm exhausted and didn't see if there were other posts.
      --Rob
      • pepsi_coke
        • 288
        How efficent would a leak down test be if you have a high mileage motor? Or would that not play an active role at all ?
        -Jay
        New member of 200,000 mile club as of May 16, 2005
        • blk92z34getrag
          • 515
          You could have a million miles and it wouldn't make a difference. The test will tell you how much your cylinder is leaking and where it's leaking to (by listening for the hissing from the places I mentioned).
          --Rob
          • Scott205
            • Jun 2005
            • 265
            I am thinking since 1, 2, 3 are all pretty low... they probably ran the engine low on oil or coolant, burning that end of the engine a bit more. If you plan on replacing the rings and/or pistons.. sounds like a good one.
            2014 Chevy Cruise LT
            2000 Kawasaki ZX-6R Ninja Motorcycle
              • 13531
              They should really all be higher than 150 too. I wouldn't get it unless you plan to tear it apart first. It may need rings or a valve job or just a gasket, but something is going to need to be done.
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                as long as it runs long enough to get out of my driveway for the next buyer i do not care. sorry been slacking on the update. the car that cam with the motor, i am going to flip it and build my engine with the profits.
