crank scraper
  • napatiger
    • 490
    crank scraper
    I have the engine on a stand so I will install the crank scraper now.
    Dumb question....
    the crank scraper mounts above the cap, then the bolt above it. Will it be the same torque....33 plus 77 degrees?
    95 MC Z34 Black
    • 13533
    RE: crank scraper
    Yup, same torque specs as stock on everything. Interesting you ask cause i was asked the same thing (close anyway) on v6z24.com.
    • napatiger
      • 490
      The reason I asked is b/c the pic on the instructions show a bolt without the extension for the baffle.
      Double post but,
      #2 and #6 rod caps hit the crank scraper and I had to grind it down about a 1/16th
      I don't really mind because I really enjoy grinding.
      95 MC Z34 Black
        • 13533
        Seems some people have them hit and others dont. Good thing you checked
