GM power book
  • Ross96GTP
    • Nov 2003
    • 24
    GM power book
    I was reading a GM power book in class today. It had a section devoted to 60 degree V6's and performance, I'm sure some of you may have seen the same book. Among some highlights of the read were. A picture of headers that crossed over the current location. They were extremely professional in appearance and if I had to guess, they were the ones made for the Beretta pace car since they were done by GM. They also had specs for the current block vs. the Aluminum Bowtie Block.
    Of other note were statements that on a performance rebuild it would be possible to swap in Double Spring Valves from a Small block v8 and also use v8 Connecting Rods. Of the rods, they stated that the length would be no problem, however the wrist pin diameter would be too large on the v8 rod and it would have to be rebushed.
    Just wondering if anyone else had read the same. Some of the ideas would really help beef up the bottom end of the 3.4 but of course in the end the death would be the 4t60.
    Just for my info, last time I saw the topic mentioned, a 4t65 swap was impossible. Yesterday I was browsing some boards that talked about a 4t65 swap into an older Wbody. That would help out tranny stability immensely but I thought the 4t65 was too big. Any feedback welcome.
    Ross
    • 13525
    We have http://60degreev6.com/download/60V6.zip
    That goes over the rods and such. The bowtie block specs are in the gp performance catalogue still.
    I dunno anything about the 4T65 swap other than wiring and computer will possibly be a problem.
    • DEI37
      • Jan 2004
      • 516
      The problem you'll run in to with the 4T65-E/HD is computer control. From what I understand, the 4T60-E isn't 100% computer controlled...there's still some vacuum control, iirc. It will bolt right up, and will physically fit...in fact, I don't think the case size is any different. It does use different axles...specifically inner CV joints. If you swap a '65-E in to a car that had a '60-E, you would need to use the inner CV joints from the '65-E, and the rest of the axle assembly from the '60-E.
      • Cliff8928
        • 532
        you could always switch to wiring/computer for a 97 to use the 4T65-E
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
