Would a 3.1L ECM work on my DOHC??
  • grandprix34
    • 168
    I strongly believe that the ECM is the caus of my car problems...ANOTHER problem is there are NO DOHC engines in all the boneyards in my area!!! So wat do you guys think???
    16149396
    Schematic
    Description: 1227727 w/ additional SRAM
    Application: 1993-94 3.1 V6 PFI ?T? LH0 (?W? body)
    1991-93 3.4 DOHC V6 PFI ?X? LQ1
    MEMCAL IDs: ?T?: BDJS, ?
    ?X?: AYSZ, BBUK, BCDT, BCFA, ?
    EPROM type: 27C256
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
    • 13531
    Only if its a 3.1 mated to the 4T60-E. They have extra sram needed for controlling the trans shift points.
    • robby1870
      Squaddoosh
      • 584
      Therefore it would have to come from a 93 3.1L
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
      • grandprix34
        • 168
        hey Ben, would a bad ECM cauz the car to run good then stutter and die? As soon as it dies i can start it right back up,but it has less get up as before but same thing, after awhile, it chuggs and dies
        - Hi-Flo Cat
          • 13531
          A bad ECM can be the cause of many symptoms, which makes it hard to say that IS the problem for anything other than no Check Engine codes working.
          • SCREECH
            • Jan 2004
            • 54
            The ECM died in my '90 Celebrity Wagon (3.1 LH0) - the car just started randomly going into diagnostic mode - while I was driving!!! Then it would, as you said, stutter and die. I would be able to get it started again, but it would run like absolute garbage until it got itself out of diagnostic mode, then it completely returned to normal and the car would operate as if nothing was wrong. Once in a while my speedo would bounce all over the place too (electric speedo).
            To fix it, I pulled the ECM box from my '87 Celebrity Wagon (2.8 LB6 I think), opened both ECMs up, and I took the chip out of the '90s ECM, put it in the '87s box, voila - I've been running it like that for the past 2 years. As long as the box you grab has the same number on it (there should be a white sticker on the side of the ECM box with a GM part number on it, make sure it matches your existing computer's number), just pull your chip and drop it into another computer. Then all your settings will be retained, but you may be able to clear up your ECM trouble - IF that's what you've got.
            Just as a side note, recently I've put my '87 Celeb back into service, so I grabbed the ECM box from the '90 Cav 3.1/LH0 5-speed, which I purchased merely for the 5-speed setup, and put the '87s chip into that box, runs fine.
            SCREECH
            1976 Olds Cutlass Supreme Brougham, 468ci BBC
            1990 Chev Celebrity Eurosport Wagon - undergoing 3.4/5-speed conversion
            1987 Chev Celebrity Eurosport Wagon - beater
            • patgizz
              The Plaid Bandit
              • 1071
              i have a 94 3.1 ecm w/ 91 dohc prom in my 94 lumina controlling the 91 engine/trans via the 94 3.1 harness - and it works fine
