Intake sealant
  • sspeedstreet
    • 282
    Intake sealant
    What is the proper sealant on the gasket between the upper and lower intake manifolds on the LQ1?
    • 13534
    None.
    • sspeedstreet
      • 282
      Nothing? Just a pressed fiber gasket?
        • 13534
        That would be it.
        • series8217
          • Dec 2004
          • 387
          The only sealant you should be using anywhere on this motor is where indicated by the rear main bearing cap and on the bottom edges of the front timing chain cover gasket. The service manual indicates where.
          • sspeedstreet
            • 282
            Got it.
