Crank Shaft Pulley
  • GTP091
    • Jun 2005
    • 232
    Crank Shaft Pulley
    I'm going to finally install my FFP underdrive Pulley. I tried to get the bolt off once when I changed out the alternator and couldn't budge the bolt with a snipe. Can anyone tell me if the bolt is reverse threaded???
    • 13531
    Its normal thread.
    • sspeedstreet
      • 282
      Are you referring to the damper bolt into the crank? When I was taking my engine apart that damn bolt was so tight I twisted the flats off with a six-point socket. The engine was out of the car so I loaded in the pickup and took it to my welder. We found a nut with an inside diameter that just fit over the bolt head and he welded it in place. Between the weld heat and the larger nut it came right out.
      • Carlspike
        • Oct 2005
        • 154
        An impact would be the way to go if you have access to one. I got mine of by wedging a pry bar through one of the openings and using a HUGE breaker bar.
