ARP main cap stud measurements?
  • FerrariFan
    • Feb 2007
    • 54
    I'm beefing up my bottom end for a turbo build and want to use ARP studs on the crankshaft caps. I called ARP and their catalog doesn't list the LQ1 or any 60 degree V6 for that matter. They said if I could find the exact measurements they could help with matching up a stud.
    I already ordered the ARP con-rod hardware from the 60V6 store.
    Does anyone here know what the exact measurements/specs are for the studs?
    Thanks
    • 13520
    Ill take some down to the machine shop tomorrow and get specs (my caliper is broke ) The windage tray will be an issue though but maybe it can be modified.
    • FerrariFan
      • Feb 2007
      • 54
      That would be great.
        • 13520
        Sorry, I woke up late (was up late porting) so I wasn't able to take measurements. Ill be good by monday to take care of it.
        • FerrariFan
          • Feb 2007
          • 54
          Why will the windage tray be an issue? Do you think I will be able to install the crank scraper as well?
            • 13520
            The studs that the windage tray bolt to are smaller diameter than the studs that go into the block. The scraper should work just fine with the stud kit since it bolts through that diameter as is.
            • FerrariFan
              • Feb 2007
              • 54
              Can I enlarge the holes on the windage tray to match the studs?
                • 13520
                That is what I plan to find out
                • FerrariFan
                  • Feb 2007
                  • 54
                  Did you get a chance to measure the studs?
                    • 13520
                    Yup, and I sent ARP the info so hopefully they can get me a part number.
