Stupidist Question of All time!
  • MONICAZ34
    • 111
    the 1994 z34 is OBD1 correct? If not what is it? Neither code readers will work in the data port. When I do the On Board SES light flicker thingy it doesn't even work if I jump the connectors like the Haynes manual tells me to.. whats the deal here?
    • 13525
    Its OBD1 with some OBD2 parts in it.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      if it makes you feel better that is not the stupidest question i have ever heard. i think the mymonte site has the dumbest lq1 questions i have ever read. one in particular was one guy asked where the wp pulley was iirc.
      • MONICAZ34
        • 111
        Okay my next question is... How come my OBD I code reader isn't working? Do the data terminals in this car get messed up? How do I check for that and how do I fix them?
        • d.o.h.c
          • Jun 2004
          • 981
          You dont use an obd 2 scanner. You need a gm plug and you can pull up all the info needed, ex, ses codes
            no, the stupidest question ever was this:
            GM engineer: "do you think we should try something different and make not an OBD1 computer or an OBD2 but... OBD1.5!?
            the rest is history
            • MONICAZ34
              • 111
              I am using a OBD 1 scanner, it has a couple of prongs on it a switch to go from OBD to ABS and it says it will work on my vehicle, but when I click the key once forward, all the SES light does is stay on. at a constant.
              • MONICAZ34
                • 111
                I even tried jumping the side by side terminals on the data port under the dash with a piece of speaker wire (like the hanes manual says to do) and the SES light just sat there with thumb in the but!
                • bve32k
                  3.4 DOHC FTW
                  • Jun 2005
                  • 475
                  I have a 95 in which I have the OBD 1.5.
                  I bought a Actron Scanner that reads OBDI and OBDII and I just use the OBDI connector to read the codes from the car.
                  OBDI you can use a paper clip, but with the OBD 1.5 you cannot use a paper clip. Have to use a scanner. I tried taking my car to Autozone and they don't have the equip. to read our cars neither.
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    i have a dated autoxray scanner and it works fine on all the obd1 gm cars.
                    • Emc209i
                      Disaster capitalism.
                      • Nov 2006
                      • 78
                      Autoxray works great mine also.
                      There are no stupid questions.
                      Getaway cars:
                      1986 Fiero SE | 2.0 OHC Turbo/Intercooled | MT2 5 Speed - 1994 Dodge Stealth | 6G72 SOHC 12v | F4a33 - 1999 Ford Windstar | 3.8 Essex | AX4S -1998 Lexus SC400 | 4.0 DOHC 1UZ | A650E
                      • MONICAZ34
                        • 111
                        so what do I need to buy for my car?
