Cam carriers, Problem here?
  • Killee
    • Feb 2004
    • 13
    Its clean above all cylinders except for #1, covered in oil. The headgaskets were fine, what else could this indicate?
  • 4spdz34
    • 185
    i see nothing wrong with that. except it says pics of cylinder heads and those are the cam carriers
    • Killee
      • Feb 2004
      • 13
      Well thats a rather silly mistake to make.
      I'm curious because over that particular cylinder is covered in oil, whereas everywhere else is fully clean. It seems to me it would have to mean something?
        • 13533
        It doesnt mean anything.
        • Killee
          • Feb 2004
          • 13
          Ok then, thanks
          • funair8594
            • 20
            FWIW here's what mine looked like when I first pulled them off at 70k
            • joey b
              • Feb 2004
              • 75
              you are considering #1 to be on the rear bank, right? Isn't that the longer head?
              92 cutty auto with a 97 3.4
              93 convert with 3.4
                Both heads are identical. There is no front or rear head (unless you want to keep the one that came off the front on the front of the engine). If you were to check the part numbers, both heads would have the same number. The cam carriers are different though.
                • 5speedz34
                  • 301
                  No difference? Well, the front head has the sender for the coolant gauge on the dash, does the rear one just have a plug there for the sender or what?
                  • Lyle's GTP
                    • Jan 2004
                    • 1345
                    Identical. 99%+ of engines are like this. Isn't the sender in the lower intake manifold? It was in all the DOHC's I've worked on and my 94'. The cam carriers are different lengths though, the front one to be exact is longer.
                    Lyle
                      • 13533
                      There is a plug in the rear. I swapped them on accident and had to install that plug while the head was bolted in. Its a close fit to do it like that but you can.
                      • Lyle's GTP
                        • Jan 2004
                        • 1345
                        Interesting, does the front head have a hole too?
                        Lyle
                          • 13533
                          the heads are the same. Its the coolant temp sensor hole.
                          • joey b
                            • Feb 2004
                            • 75
                            I ask because on the front bank the cylinder closest to the timing belt (#2, right?) is the farthest from any PCV because it is on the right of the front bank and on the rear has it close to the middle so that could cause some builld up above the #2 cylinder.
                            93 convert with 3.4
                              • 13533
                              The PCV connection is right above the #2 cylinder though, so what would that have to do with anything? Techincally the number 1 and 6 cylinder areas are the furthest from the PCV connections. The oil moves so quickly though that I dont think there is much cause for worry unless you are making short trips only and the oil never warms up enough to burn off contamination and evaporate condensation (if any).
