help with o-ring repair.
  • camaroguy
    • Nov 2006
    • 17
    so i as per this thread:
    http://60degreev6.com/showthread.php?t=37463
    i ground down the top of the drive but i can seem to get it up past maybe an 1/8 of an inch. the grinding did nothing.
    anything i over looked?
    i have pics but they are blurry so i'll post them if i need to.
    thanks
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    To do it right you NEED to take off the rear head. Otherwise you can just pop it up, clean the general area really well and then apply a nice layer of RTV. It'll hold up for a year maybe. It's up to you since it is your car.
      • 13496
      Did you grind off the bottom of the head mounting tab? That is necessary. I hate this method of repair but if you like to gamble, it may work. I had no luck and will never try to do a shortcut on this motor again.
      • camaroguy
        • Nov 2006
        • 17
        no it didn't say to. i guess you use the outline of the old gasket as a guide?
