Timing Belt Accident
  • 1995gtpGPdohc
    • Feb 2007
    • 10
    OK, I have 2 questions. First I am replacing my timeing belt and I dont want to change the timing at all. I am happy with the current timing so I was making sure that as long as I lined up all the timeing marks on the cams before I took the old belt off that all i have to do is take the old belt off and put the new one on without moving anything and it should start right up and run like before correct?
    Second, I started this a day ago and while i was in there I took off the tensioner actuator and had to put it on and take it off several times because I missed the little cup that the ball thing on the end of the actuator fits into. I guess in the process I over tightened it and I broke the fitting that the actuator slides into (closest to the engine block) it is like a cast aluminum piece with a copper fitting in it. I was wondering if the dealer will have this part or if anyone knows the part number or just if anyone has done this in the past becuase it seemed like it broke pritty easily just from me having to take it on and off a few times? Thanks
    http://www.cardomain.com/ride/2504648
    • 13522
    I always retime the motor so I can't help you on shortcuts to do it. For the brken piece, its a piece of shit casting and they like to break. You may be able to get one from the dealer still. I got the other bracket last year (that the 2 13mm bolts go through).
    • series8217
      • Dec 2004
      • 387
      I broke one the same way. I got it welded at my machinist.
      • series8217
        • Dec 2004
        • 387
        Here is the part number if you want a new one:
        10162152 - Timing Belt Tensioner Actuator Bracket
        This is the part number that was cast into the bracket.
        GM list price is $95. You can get it from gmpartsdirect.com for $68.92 shipped or partszoneonline.com for $62.47 + shipping.
