Rounded off bolt in worst spot, ideas?
  • pontiacdohc@gmail.com
    Pontiac DOHC
    • Feb 2006
    • 181
    you could always take the cam carrier off i think thats your best bet if you dont have any tools to get it off . with the carrier off u can take it welding shop n have them weld a nut to the bolt or u can try hammer something on there ur self
    1997 Chevrolet Camaro 30th Anniversary 5Speed.
    3800 V6 (i know its not a 60degree)
    stock for now
    1993 Special Edtion/GTP
    3.4 DOHC V6 LQ1 SOLD!
    CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
    180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
    VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
      Pontiac DOHC
      • Feb 2006
      • 181
      some one was thinking alike lol
      stock for now
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        Take the carrier off x2.
        wow, if you are completely out of ideas, you could try grinding and re-flatening the sides to retry a 15mm socket or grind them enough to put a 14mm on there?
        • heza
          • Apr 2004
          • 96
          well, last night i said f it and pulled out the dremel and a handful of spare cutting discs. although its not the fastest, i took a lot of the bolt head off where i in theory would drill it out if i had the space. once i get down to the lock ring, i will break the other pieces of metal off and pop the sprocket off. hopefully then i will be able to vice grip the leftover bolt and remove it.
          thanks a lot for all the responses!
          • Dave96z34
            • Apr 2005
            • 624
            I sent you a pm like a week ago. All you had to do was IM me and I could of told you how to get around that.
            • oceancon
              • Nov 2007
              • 11
              #21
              Keep soaking the bastads with PB blaster and get the vice grip on it - heat it too - work it, it'll come out. its in a tough spot to drill the bolts out if you grind the heads down...
              • Juglenaut
                • 1130
                #22
                The point being that just use 6 point sockets on high torque bolts and where the extra points are not needed. I only use 12 point sockets if the area is tight and need more possibilities.
                A 9/16 6 point may be easier to pound on a rounded 15mm. 17/32nd if you need more holding power. I had this happen way back and used a deadblow hammer to pound it on I can't remember which cam.
                I am back
                Mechanical/Service Technican
