Rounded off bolt in worst spot, ideas?
  • heza
    • Apr 2004
    • 96
    yes, those are the rear camshaft sprocket bolts. fronts came off perfect, those did not.
    TRIED: heating/cooling, socket, wrench, vice grip, craftsman bolt-off
    WILL ATTEMPT: carving the bolt head off with Dremel and then taking bolt out after pulley is off. do not have welder to weld on another bolt, so not an option.
    i need more inputs please!
  • silvergtjrad
    uber slow grand am
    • Feb 2007
    • 302
    impact.
    • heza
      • Apr 2004
      • 96
      Originally posted by silvergtjrad View Post
      impact.
      i really wish i had an impact wrench available along with 15 mm pivot socket
        • 13520
        Hammer a cheap socket on there that will barely kinda of fit.
        • pontiacdohc@gmail.com
          Pontiac DOHC
          • Feb 2006
          • 181
          thats sucks too bad u dont have a welder i ran into the same problem with the harmonic balancer bolt on a 3100 i just did i grinded the head of the bolt down and beat a big nut over it and welded the inside of the nut it came right off,
          have u tryed using of them sockets that take striped bolts off ?
          1997 Chevrolet Camaro 30th Anniversary 5Speed.
          3800 V6 (i know its not a 60degree)
          stock for now
          1993 Special Edtion/GTP
          3.4 DOHC V6 LQ1 SOLD!
          CHIPED,CAI,EXHAUST 2 1/2 SUMMIT TURBO MUFFLERS & NO CAT,,AC DELCO RAPID FIRE PLUGS,
          180 STAT. FUTURE MODS,50,000v COILS,FFP PULLEY,FFP DOGBONE!
          VIDEO http://vids.myspace.com/index.cfm?fu...oid=2020589230
            Pontiac DOHC
            • Feb 2006
            • 181
            something about GM and there 15's striping out, i had to drill all 4 cradle bolts out when i did my trans!
            stock for now
            • 93 prix se
              • Jan 2008
              • 6
              without a welder, and without taking the cam box off, your best bet is probably grinding the heads off, removing the sprockets, then removing the bolts. Had to do the same thing with one of mine. One thing I learned, always start with a six point socket. Those s.o.b.'s can be extremely tight!
              • geldartb
                The Situation
                • May 2004
                • 1994
                one thing i learned a long time ago always use 6 point sockets unless you need to use 12 points.
                all 12 points are good for is rounding shit off unless you need them for say example rod cap nuts.
                99 Grand Am GT
                1357 cam 227 233 .050 dur
                515 515 lift 112 lsa
                • heza
                  • Apr 2004
                  • 96
                  yup, i got the craftsman bolt-outs and couldnt 'tap' the bit onto the bolt head because there really isnt enough space. so when i had the bit on as best as possible and tried, it just rounded out the head slightly more.
                  i said screw it and will give it all a whirl tomorrow. just sucks cuz first i had the idler pulley issue and now the camshaft sprocket bolt issues; the two events defining the tear down/assembly transition.
                  • silvergtjrad
                    uber slow grand am
                    • Feb 2007
                    • 302
                    On my spare motor I broke 3 snap-on and one mac impact socket trying to get the crank bolt out. I finally got it after I hammered a 14mm onto it and used the impact again. Oh, and then I broke a pulley puller trying to get the crank pulley off. I ended up heating the shit out of it with a torch and yanking on it with a slide hammer.... FOR AN HOUR!!! Thank god that thing was on a stand and not in my car!!
                    • pwmin
                      • Aug 2004
                      • 394
                      we had to cut mine off w/ a cutting wheel and then use an air chisel to knock it off. cant remember exactly what we did.
                      91 GTP HM-284 GONE :(
                      98 Spawn of Satan (L67 Regal)
                      87 V10 SM-465/Mild 350
                      06 Cobalt SS/SC GONE :(
                      • heza
                        • Apr 2004
                        • 96
                        ^ what hell that mustve been. unfortunately, motor is in the car and i dont quite have the space to hammer anything on. i tried pressing on it with a breaker bar using lower frame as a support and that didnt work too well.
                        • jp_grasshopper_007
                          Power Level:1,000,000
                          • Mar 2006
                          • 120
                          Craftsman 14-piece Bolt-Out Set with Case
                          Sears item# 00952062000 Mfr. model# 52062
                          because I\'m not Canadian
                          • heza
                            • Apr 2004
                            • 96
                            own it...doesnt work unless you can get it seated on the bolt better than i can at that position. cant hammer it, cant press it.
                              • 13520
                              I wouldn't expect that to work anyway because of the torque you need to apply to the bolt. Probably just cut it up more with the craftsman set. You will probably have to pull the rear cam carrier off so that you can get to the bolts easier. I have had to do this for the same issue you are having, though I didn't round it off that much. Get a socket hammered on and then impact it.
