I need to temporarily turn off the fuel pump as I want to run a can of fuel injector cleaner through the injectors. I have pulled the fuel pump relay from the fuse panel on the passenger side of the car. This is the only thing clearly marked fuel pump. When I pulled this the car continued to run as normal. I pushed the accelerator to hopefully use up the remaining fuel in the lines but I don't think the pump is turned off as the car ran for a good 5mins. the only other thing they claim for the fuel pump is the ECM fuse. I pull this and nothing works at all so that can't be the way to go. Is there something else I am missing???
I'm going to jack the car up tomorrow and see if I can get at the fuel pump plug easily. But if anyone has any ideas as to why the relay doesn't kill the car let me know. I have the relay pulled right now and the car runs like normal...
