What can I use as a cam hold down tool?
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    little late on the response but i'll add it in anyway. when you bend your keystock like that, the gears may be frozen in place. i have done a number of things to loosen them up before.
    1st you put pressure on the gears/belt and tap on them with a plastic hammer until you see the gear move. if that doesn't work, i have also used a large screwdriver and wedged it between the gear and the carrier and i would wiggle it back and forth(as to pry the gear off) until i pushed the actual gear out about 1/2 and inch, then simply tap it back into place with the plastic hammer.
    do that about 3 times per gear(using penetrating oil if necessary) and go back to the first procedure if need be. i haven't met a set of 94+ gears yet that hasn't given into that.
      Or if you don't have a plastic (dead blow) hammer, a regular hammer and a piece of 2x4 work too.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        yep yep field engineering at it's best
          Sometimes its necessary when the vehicle your working on is the only one around that you are able to use to go get tools/parts. Luckily I don't have that problem, lol.
