please help
  • savannaz34
    • Jun 2008
    • 72
    Question : please help
    i messed up my throttle body shaft and i cant find an upper intake for my 92 z34.so i was wondering if any other throttle bodies will have the same parts?
    o can i easily customize it by welding on a bigger throttle body?
    plz,im very desperate as i cant find a upper any were
  • GTP091
    • Jun 2005
    • 232
    91-93 are all the same; you can remove the throttle plate and shaft from the plenum but need the parts. Your better off just replacing the whole thing rather than pulling it out. So you'll have to hit a junkyard. What were you doing that caused damage to your own unit??
    1991 Pontiac Grand Prix GTP / 3.4 DOHC
    • savannaz34
      • Jun 2008
      • 72
      the reason i stripped it was to polish out the upper intake,when i took it apart i twisted the shaft.
      but my father in law and i actually straightend it last night,and it worked
      so far...not sure if it will until i put the upper back on but it looks good.
      as for replacing the upper with a used one.cant find any were(locally)
      i cant find a international,grandprix,or a lumina with a 3.4 any were around here.
      thanx for replying
      • GTP091
        • Jun 2005
        • 232
        If it was twisted and you straighteed it the shaft is likely still bent?? if i is don't expect it to line up properly. if it doesn't your car won't idle properly. tps will say it is at idle but the rpm will be higher if leaking past the tb plate. could throw a code.
        • savannaz34
          • Jun 2008
          • 72
          i put the intake back on and fired her up,and it seems to be fine.i wont be driving it until im done.but im hoping everything is all right.
          the flap closes nicley(no visable gaps when closed)
          • GTP091
            • Jun 2005
            • 232
            sweet! hopefully you got it all licked.
