anyone know what these wires are?
  • no_doz
    • Sep 2005
    • 912
    Question : anyone know what these wires are?
    these are unplugged/disconnected-any ideas what these go to ?
    the one wire connector: i've NEVER seen it plugged into anything, so i don't know what, if anything it goes to.
    the second one, i'm not sure, can you get a better pic of it?
    comparing to the ones on eficonnection.com might be able to help as well.
    and what exactly is this? i see the file named GTP 07, and i see a MAF as well, so i'm going to assume 94-95 GTP?
    • no_doz
      • Sep 2005
      • 912
      its the 94 gtp automatic with the stock 3.4 dohc engine in it-sorry about that.
        i took a quick look through alldata and the only thing i found with red and blue wires, that would be around there, is the washer fluid connector...
        i don't remember what the engine bay of GTPs looked like in 94, so that may not be it.
        • bve32k
          3.4 DOHC FTW
          • Jun 2005
          • 475
          That wire is def. for a windshield wiper fluid pump. It shouldn't go anywhere else. Plugs in by the battery.
            cool, thats what i thought, i know(think) the washer bottle got moved around a few times before the GPs body changed in 97...
            • bve32k
              3.4 DOHC FTW
              • Jun 2005
              • 475
              That blue wire looks like a aftermarket wire.
              Edit: Take a pic of where the battery is.
                ??? it looks fine from the pic...
                well, no_doz whenever you decide to post again, you should have all of your answers...
                EDIT: OK, now i see what you mean by blue wire... why is it going through the wheel well? i'm guessing its for a saound system, but it would have been a better idea to use the grommet next to the brake booster.
                • bve32k
                  3.4 DOHC FTW
                  • Jun 2005
                  • 475
                  I sure hope I said everything correctly..Cause I am spinning. Damn alcohol.
                  • 1988GTU
                    LB62LHObbqftmfw
                    • Nov 2005
                    • 2475
                    Blame it on the ah-ah ah-ah ah-al-co-hol.
                    • 94GPGTP
                      95 Grand Prix GTP
                      • Apr 2007
                      • 593
                      LMFAO
                      Robert
                      New Rebuilt 3100
                      New Rebuilt 4T60-E
                      Exhaust
                      Drilled/Slotted Rotors
                      White
                      3" Magnaflow Catback
                      90 Pontiac Turbo Grand Prix
                      5 Speed Swapped
                      127,000
                      Spec Stage 3 Clutch
                      230,000 mile Getrag 282
                      Emissions Deleted
                      Brand new Engine 1,000 Miles
                      Fully Custom Built car
                        The single red wire with the gray connector is your fuel pump test lead. Touch it on your jump start terminal and you should hear your fuel pump start running.
                          THAT'S what that is? .......wow, who'd a guessed?
                            Si senor. I wondered after I got my car and did intake gaskets, thought I left something unhooked so I started asking people and found that out.
