How would you know or the symptoms of a 3.4L DOHC engine thats off time. I think my timing is way off time because I have two hand written marks that I believe line up but one is off by 4-5 teeth on the cam sprocket.
Symptoms of Engine Out of Timing
Question : Symptoms of Engine Out of Timing
sigpic1993 Pontiac Grand Prix SE, 3.4L DOHC 24 Valve V6 MFPI, 5 speed, completely stock, bucket on a budget!Tags: None
The only way to really know if it is out of time is to pull the valve covers and check to see how the cam flats line up in relation to the crank. If marks on the cam gears don't line up, I wouldn't worry, it probably means someone did the cam timing right the last time the belt was changed.
http://60degreev6.com/content/Cam_Ti...re_Walkthrough-60v6's 2nd Jon M.
