hydrolic lifters...hellppp!!!
  • 93vinx
    • Dec 2003
    • 154
    i ahve 2 sets of hydrolic lifters, one set the center move in freely the other set they move hardly at all, some move a little and some not at all, what are they supposed to act like ?
    vrrrooooooooooooooooom i need new exhaust
    • 13520
    You want a set that doesn't move at all, or less than 2mm give to them by pressing in.
    • 93vinx
      • Dec 2003
      • 154
      ok, well after talking ot my machine shop, they told me they can be taken apart, i'm not sure if he knos the exact lifter, mine move around 4 mm, is there a spring or what?, don't they fill with oil,
        • 13520
        There is a spring in there and there should be a checkball (maybe not on our stock lifter?). They fill with oil and the oil pressure keeps them somewhat solid.
        http://www.ina.com/inaupdate/news/pu...ulation_gb.asp
        Check that out.
        • 93vinx
          • Dec 2003
          • 154
          so as for movement, minimal would be better?, or does it not matter when filled with oil?
          wow there is alot of info there, lol
            • 13520
            Well, it still matters when they are pumped with oil. They shouldnt move very much if at all without any oil pressure on them. At idle, they will pump up a lot, and at WOT they will probably have a bit more give than you can get away with. Its a performance issue as well as maintenance, but if they aren't collapsed, they aren't dead (gotta run em to know if they are collapsed though).
            • 93vinx
              • Dec 2003
              • 154
              so if the spprings isn't bad really the lifter should be ok if its not grooved or ne thing, do they come apart?
              • 93vinx
                • Dec 2003
                • 154
                ok so i pulled them apart and the one set sprins up and down
                the other does not, the good ones should spring
                • CurtsLuminaZ34
                  • May 2004
                  • 25
                  GM posted a fix for lifter noise in the form of a technical service bulletin. It requires some drilling on the cams under the end covers, but the TSB improves oil flow the the "hat" style lifters our cars use. The service kit is suppose to be availible from GM. I will check this week and see if the kits can still be ordered.
                  \"Experimentation\" the mark of a verteran weekend garage warrior
