backfiring in the throttlebody
  • jdellinger1980
    • Dec 2009
    • 36
    Ok I just changed my injectors out, moved my coils, and replaced all my hoses and now when I start my car the idle goes up really high and comes down really slow and if you touch the gas it does the same thing and then it will start backfiring in the throttle body and trying to cut off, anybody ever had this problem after changing the injectors?
    =Joel=
    • 13525
    Could have a vacuum leak in the injector o ring to manifold, or the TPS is not reading 0% throttle at idle for some reason.
    • Weatheralls Auto
      Spinning out of control
      • Dec 2009
      • 536
      Ya sounds like a Vacuum leak to me, Inj Oring may not have seated correctly.
      High idle with a slow drop or popping back through TB usually indicate a vacuum leak or very lean condition due to leak.
      As of April 2
      Engine: 2006 SV6 3500 LX9
      Trans: 2002 Getrag F23 5speed
      Injectors: #36 GTPs
      TB: 65mm TCE
      Maf: 1999 3400 Montana.
      Beverages: Ice Cold CANADIAN.
        ugh...
        • jdellinger1980
          • Dec 2009
          • 36
          So I guess i need to pull the throttle body back off and check the injectors again, huh. Any other solutions on what to do? thanks.
          =Joel=
          • bve32k
            3.4 DOHC FTW
            • Jun 2005
            • 475
            Check your TPS sensor make sure it is plugged in. Make sure all the vacuum lines are plugged in too. Did you replace the injector o-rings when you replaced the injectors? Did they seat properly when you pushed the rack down? Did you replace the Upper Intake Gasket when you took everything apart and the o-ring for the coolant under the throttle? Make sure the PCV is pushed in all and also make sure the brake booster vacuum line is correct.
              plug wires in correct spots?
