HELP!!! does the start on a 92 z34 have a shim!??
  • twixt
    • May 2004
    • 7
    • 13522
    no. I had an issue with a starter for a while and it was the power wire going to the starter. Just curious if you are asking because the starter will ping but not spin the flywheel? If so, check your wires. You shouldn't need to use a shim. In fact, I shimmed mine so many different ways trying to figure it out and then I noticed the real issue.
    • bud36light
      • Nov 2003
      • 517
      Ditto. Also DO NOT go with a local neighborhood shop on these starters. Go for a quality starter from a supplier instead. I tried 2 different shops around here and $100 later I still had an intermintent no start. A trip to Napa for a premium grade SOLVED the prob.Im sure someone will argue but this did work in my case. Got tired of my wife calling saying "my car wont start".
      2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
      • Mitch DOHC
        • Jan 2004
        • 261
        i have had the same thing happen as well.... solved it with a good starter
        1994 Cutlass Supreme Convertible 3.4 DOHC
        1969 Oldsmobile 442
        1997 Chevy Tahoe
        http://members.cardomain.com/mperkins442
        • blk92z34getrag
          • 515
          We went through 3 different brand starters in a week before just going for a new AC Delco Starter on my mom's Euro.
          --Rob
          • twixt
            • May 2004
            • 7
            my dad was working on it and hes getting so old he forgot if it had one, he says he was pretty sure there was and he thought he lost it, i told him there wasnt. we replaced my bad one with a napa and it works great. it just wont start on the first time when its cold. it hasnt since i have owned the car so its not the starter.
              • 13522
              check your cables to the starter and the ground for the battery. Mine had a real hard time when I had a bad ground and a crappy solid metal bar for a connection point on the power side. Too much resistance in that setup.
