3.4 dohc lifter and or rocker
  • Kwixtar
    • May 2004
    • 10
    92 Pont GP 3.4 DOHC - I have a bad lifter and or rocker arm knock under the front valve cover. How difficult will it be to replace?
    1. remove valve cover, of course!
    2. do I have to remove the cam, timing belt? anything else?
    3. any adjustments?
    4. any precautions?
    92 Gran Prix SE 3.4 dohc that has a bad knock in front head. I think it is a lifter or rocker.
  • Mitch DOHC
    • Jan 2004
    • 261
    well this will make it easer u will not have to mess with any rocker arms... i promise
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
    • dbtk2
      • Feb 2004
      • 349
      if its a rocker arm I will be VERY SUPRISED...I just have a hunch that it isn't a rocker arm...don't know why though.
      99 Grand Prix GT
        • 13522
        You have to pull the cam carrier to get to the lifters. There are no rocker arms, the cams ride on top of the lifters directly.
        • napatiger
          • 490
          where can I get new lifters?
          95 MC Z34 Black
            • 13522
            Well, gm, autozone, advance, or me. I haven't found the stock replacement lifters for cheaper than what I sell mine for ($12.50 each), and mine are 18% lighter as well. If you aren't replacing the whole set though, I would stick with stock replacements.
            • napatiger
              • 490
              What makes your lifters lighter? BTW your store will be cool when it gets up!
              When I pulled the carrier...I had the towel on top so the lifter fell all over the place <--what a newbie>
              95 MC Z34 Black
              • Anonymous
                Ben are your stock replacement lifters 18g lighter, or are your performance lifters 18g lighter? Or do you only have one type? Just curious...
                  • 13522
                  I don't sell stock replacements, just the lighter ones. They don't have a heavy weight on the face of the lifter basically. They are the same dimensions that matter (shorter side skirts, like the quad 4s, thats about it).
                  • Anonymous
                    That's what I wanted to know, thanks
