None that would make a difference to the starter. I usually use a 1/2" ratchet and socket on that bell housing ground.
tps sensor
Well after a batt change car runs great till getting hot ,then again after shutoff it will bog for fuel,dont know where else to look at,if i let it sit for a few hours runs great,now could be a bad egr of fuel pump,also if i feather the gas pedal to get rid of the bog it runs strong.
Thanks all for your advise,turned out to be a bad fuel pump,changed out and all is good for now.
