Monte alternator in lumina z34?
  • Rabbi
    • Jun 2005
    • 110
    Question : Monte alternator in lumina z34?
    Will the monte carlo z34 alternators fit the 92 lumina z34?
    Thanks
    Any 3.4 DOHC alternator should swap between model lines physically. Not sure if the connector on the back changed any from 91-97, though. Check part # vs part # at the parts store to be sure.
    • jmgtp
      • 1219
      Thanks
      The connector on the back changed in the later years. I want to say it happened in 1994-95 when they went to the OBDI.5.
      I've got a remanufactured alternator that will fit your 92 Z34 for sale in the buy/sell section of the forum for $50 total (no additional for shipping). It has an overdrive pulley on it, meaning it spins the alternator a little faster for better output at idle speeds. I can put a regular sized pulley on there if you like. It has less than 1,000 miles on it: http://60degreev6.com/forum/showthre...-Dogbone-Mount
      1994 Corvette
      LT1/ZF6
      2006 Dodge Dakota 4x4
      3.7/42RLE
