its pricy but has the 2 flats for the cams and the cam holder and gear remover... i thought i heard there were out of production!
found timing belt tools that are still being made
its pricy but has the 2 flats for the cams and the cam holder and gear remover... i thought i heard there were out of production!Tags: None
No the stock tools are available, but the adjustable stuff is gone.Ben
i forget my measurements, but roughly, 5"x3/4"x3/4" solid bar stock.
I had 2 bars made with a hole through the middle and had the surfaces machined within .004" tolerance, then blued them. It cost me $65, at a local machine shop, to have them made from a rough sketch, and $4 for the bluing to prevent rust. They are so strong I can break the bolt free and torque it again when I adjust timing.sigpicHow to make High performance Emissions:
on here it says 1/2 bar stock and 5/8"s hole IIRC. in the reference section.... im still tempted to make adjustable ones by adding spacer blocks or screws to hold the cam flats. just dont know the dist change to build them yet.
What did you have it made out of, aluminum?Originally posted by Dave96z34 View PostI made that before it didn't work all it did was bend and crack. I have the ajustible timing tool
Mine are tool grade steel.sigpicHow to make High performance Emissions:
