stalling
  • grandprix34
    • 168
    they replaced the voltage regulator on my alt. TOok pictures too.
    \"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
    - FFP UD Pulley - FFP Chip - 8mm Taylor Wires
    - 160* T/stat - Dual 40 Series Flowmasters
    - Hi-Flo Cat
    15.2@95mph - GTECH P/B
    http://home.rgv.rr.com/tjperformance/Cap0005.mpg
    • grandprixgtp_91
      • Nov 2003
      • 758
      I had the same problem with stalling and when i cahnged my clutch and did my timing it stopped completely. all i can say if it is idling below 1000 rpm raise your idle with the set screw till it hits 1000 rpm.
        • 13531
        You don't change the idle with the throttle stop screw. The computer controls the idle via the IAC (idle air controller). If you set the stop screw so the throttle is cracked open, the IAC will try to compensate. If you go to far, it will throw a code. The computer also retards timing trying to lower the idle speed to what it is set to in the computer.
        • grandprixgtp_91
          • Nov 2003
          • 758
          no you can cahnge the idle a little bit with the set screw i have had this problem before and when i changed it it worked fine.
          • 93GTP
            • 125
            It might change a little, but it's not the set screw that actually determines the idle. It's like Ben said, the IAC does.
              • 13531
              #21
              Its not even a set screw. Its the throttle stop screw, so that the plate doesn't stop against the walls of the TB and get stuck.
                Turns out my stalling problem on the 92 was 2 things. The alt, and the vacuum line that hooks to the FPR came unhooked somehow. Fixed it, and now the lights are nice and bright again, even at idle with the fogs burning, and the stereo bumping, and no more stalling, thank heavens!
                • blk92z34getrag
                  • 515
                  #23
                  FPR? What's the stand for (still trying to figure out my stalling problem)?
                  --Rob
                  • robby1870
                    Squaddoosh
                    • 584
                    #24
                    Fuel Pressure Regulator
                    Robby Whitesell
                    2006 Pontiac G6 GT
                    1985 Toyota Pickup DLX
                    • Anonymous
                      #25
                      Ok hey guys.
                      This is Aaron from the w-body forums-I'll behave.
                      Anyways, my car does this religiously. I took it to the dealer, they charged $250-replacing my IAC, and all vacuum hoses. Didn't do a damned thing. So now I've been thinking about it. I hit the headlights at idle, and the car's idle dropped bad. It is a charging problem. Ever since the battery in the trunk, and the UD pulley, the car is doing it. I think I'm gonna put my old pulley back on to see. Then we will see if it fixes it. i thought it may be the EGR, cuz the chip turned it off, so i had Ben replace the EGR-didn't help. I'm also worried its charging cuz the blinkers do hell to my idle. We all know the gauge is off, but it jumps around 200 either side of 800 when the blinker is on.
                      I just wanted to help out, as there aren't a lot of 5-speeds and it seems many of us are having this problem of stalling. I'll watch my comments on this board for sure.
                      • Crimson Fury
                        dropped your pocket
                        • 111
                        #26
                        for the "idle" screw, how far does that thing need to be from the bottom to be "stock"?
                        http://www.w-body.com/forum/viewtopic.php?t=24111
                        Car Domain site!
                        13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
                        • Crimson Fury
                          dropped your pocket
                          • 111
                          #27
                          oh, i used to stall to, until i got the 13* retard. its a rough start in the mornings @ idle, but not even 5 minutes of running time and its good to go
                          Car Domain site!
                          • Anonymous
                            #28
                            I havn't had time to change the pulleys out yet, I will on Sunday.
                            • BowtieKid79
                              • 59
                              #29
                              I highly doubt your stalling problem is a result of the battery being in the trunk or the UD pulley. I have both of those and i dont have a single problem. Make sure your wire to the battery is making good contact and make sure you have a good ground. a bad ground will screw a lot of things up.
                              • Anonymous
                                #30
                                I have doubts too-many people are using your products succesfully(including yourself) but it is worth a try and it isn't that hard to change. I have good contact with the battery and a good ground, checked those. I do not have a SES light either.
                                I am also going to take off the fuel rail cover and check that the vacuum hose going to the FPR is attached well, which I believe it is, but also worth a try.
