CAR IS DEAD
  • CodeRed
    • 44
    CAR IS DEAD
    it will start for a moment then die even when tryign to give gas to it also it seems to back fire through the intake
    also u have to prepump the gas peddle to get it to startup
    some have said catalyic converter or maybe fuel pump
    any ideas???
    btw this is for my 93 cutlass convertible 3.4 DOHC
    Z24 Cardomain Site ll ZQ8 Car Domain Site
  • quantum110
    • 175
    The ECM Cut's fuel if you pump it in an efi car...
    Did you check your timing belt?
    67 Olds Cutlass 2bbl 330 w/ 2 speed Jetaway
      • 13525
      Is the crank position sensor good, or the wiring from it? Cam timing could be it as well, or leaking injectors. Pumping the plate doesn't do anything for you so I dunno why that would help. Maybe you have a bad TPS?
      • grandprixgtp_91
        • Nov 2003
        • 758
        what about the coolant temp. sensor? doesnt this cause almost the same problem? im not sure.
        Jake
          My coolant temp. sensor broke (my fault when changing intake gaskets) and the car still started and ran. It didn't run as smooth, or start as easy as normal, but it still started and ran ok.
          • CodeRed
            • 44
            well i had the timing belt checked back in october when the car had a oil leak fixed and they said it was still in good condition
              But how many miles was put on the car since then? A belt can still look good and be bad. The one on the 91 that shredded looked somewhat decent from up top, but was shredded to peices where it wrapped around the dummy cam pulley.
              • CodeRed
                • 44
                maybe 8-10,000 problem started out as the car was lacking alot of power when i gave it alot of gas the car would get up and get going but now only stays started for a second or 2
                • Warrick
                  • Jul 2004
                  • 24
                  sounds similar to the problem I had with my Z34 when I first bought it, there was actually a coil pack busted, does your car stink of gas? As for your issue with the high throttle power loss, check out my post about halfway down this page, I also had the same problem with my car, turns out it was just regular maintanance work - with the plugs, wires, PCV valve, O2 sensor, fuel filter, air filter, could be any of those things really. I noticed with my car that when I was pushing high throttle, it felt like the engine was responding to the pressure, but it just wasn't picking up, are you experiencing the same thing?
                  1992 Lumina Z-34
                  There\'s No Replacement For Displacement
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    check your fuel pressure at the test port for sprayage. i have had leaky injectors be4.
                    • CodeRed
                      • 44
                      well guys got the car fixed ended up being the fuel pump ehh go figure
