idle screwed up
    • 13534
    Glad that fixed it for you
    • papitony69
      • Nov 2004
      • 16
      Bubba81,
      Can you tell me what gaskets you replaced in the process of doing the lower intake gasket ?
      Also did you fix the o-ring oil leak ? Anyone ? I am going to do the lower intake this weekend, and want to do the o ring leak too...
      thanks
      • bubba81
        • Oct 2004
        • 32
        the only other gaskets i had to replace was the egr spacer to plenum gasket.
        1995 Chevrolet Monte Carlo Z34
        • bubba81
          • Oct 2004
          • 32
          I was going to replace the orings on the fuel injectors but they looked surprisingly good for how old they are. I did'nt have to replace the distributor oring because i have coil packs no distributor
          • papitony69
            • Nov 2004
            • 16
            Ok I just finished the job, I replaced the following :
            Upper and lower intake gaskets, fuel injector o-rings, egr adaptor and eger valvve gasket.
            Did a tune up while i was at it, and JB welded the oil o-ring thing...man i used a lot of JB !
            The only this is that the oil oring spins....well it used to not anymore...is that a problem ?
            • 93Oldsdroptop
              • 167
              #21
              Nah, doesn't matter if it spins. I did the wife's LQ-1 over a year ago and it doesn't spin or leak. That was with the Chevy distributor gasket and hi temp silicone.
              Yeah, it's not too bad a job with the correct amount of beer and patience!
              '93 Cutlass Ragtop LQ-1 -- Semi-retired over winters
              '06 Dodge Magnum SXT 3.5L -- My Daily Driver
