Delco plugs and gap
  • heza
    • Apr 2004
    • 96
    Delco plugs and gap
    so...today i went to my favoritist parts counter to get my replacement platinum Delco plugs recommended for my motor and i came out surprised. did anyone else know that AC Delco changed the part number and now offer Iridium plugs in place of the platinums?
    i didnt, so now have Delco iridiums to install.
    also...when i pulled just one of my old plugs, i noticed the gap on it was .65 inches instead of .45. would this be where my shitty mileage was coming from?
    just curious...
  • dykz34
    • Jan 2004
    • 793
    The bigger gap might have been causing your MPG issue... not sure though. What does the sticker on the front crossmember say to gap the plugs at? I believe my 92/93 cars say .045.
    • heza
      • Apr 2004
      • 96
      i put .45 inches...but actually, it was .068i and my car is spec'd for .045i. i wonder if that would make my car not smell like gas when running. also...injector number 4's lower o-ring was shredded!
      • dykz34
        • Jan 2004
        • 793
        Shredded o-rings = bad. Good thing you tore your motor apart to find all these problems.
          • 13522
          Larger gap can cause MPG problems, and a leaking injector I ring will definetly cause issues. A 96 GTP though may want .060 or something like that. I know GM increased the gap on the gen 3 pushrod motors but no clue on the DOHC.
          • heza
            • Apr 2004
            • 96
            nope...'96 DOHC is .045i too.
            Dave...tearing the engine apart led me to find many little things to replace. oh well...she better run like a damn champion when im done! just gotta get the motivation to finish polishing that damn cam cover.
            • brian89gp
              • 554
              I tried out .055 gap for a while. Slight low end torque increase but it would misfire bad above 4k or so.
                • 13522
                I tried .075 with my DIS-4 in my 3.1 back in the day. It ran, gas milage was the same as stock but i didnt notice any gains. Put it back to stock and got 1-2 mpg with the box. Figured I could throw that in for whatever its worth.
                • 97montez34
                  • Jun 2004
                  • 22
                  96-97 DOHC's should be the same for plug gaps no matter what car they r in. my sticker on my car says .060 for plugs. ive looked at 95's and they say .045 so for whatever its worth, u might wanna re-check on where your getting your info from, because there shouldnt be a difference in plug gapping from 96 to 97..only 95 to 96
                  \'97 Monte Carlo Z34- Milzy Motorsports 2\" Headers, 2.5\" Mandrel Exhuast, Ported & Polished Upper & Lower Intakes, Ported Intermediate Arm, NGK TR55\'s, DHP PCM, 180* T-stat, EGR Delete, GM STB, GMPP Trailing Arms, & Coldz CAI w/ K&N cone.
                  • heza
                    • Apr 2004
                    • 96
                    my service manual says .045 for it and thats what i have it set at. hopefully it doesnt hinder anything cuz i dont feel like pulling the upper intake again. havent run it yet because i need to finish polishing the cam cover still. just got back from an exercise for this past week.
