dohc headache = code 42
  • Crimson Fury
    dropped your pocket
    • 111
    intermittently throws the code. symptoms; sputters/pops while starting up, while idling, rpms sputter and die if i don't stablize the rpms, this occurs while braking to a stop or braking for a corner. this crap started thursday and finally today it threw the 42. man was i happy to see SES!! :P i'm going to rule out the tps and iac, they are no more than 2 years old. i might check the map, and i might point a finger at the O2 and amybe the ignition module(icm). the auto zone lady seemed sure that the control module(i assume she meant icm, but just said control module). any insight to this headache will be appreciated
    http://www.w-body.com/forum/viewtopic.php?t=24111
    Car Domain site!
    13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Well, it is either fuel, or electrical. (Man, I'm a lot of help) scootin' to a corner to hide.. :P Actually code 42 is an ignition spark control problem. Does it do this only at operating temp? Reason I ask is, sometimes the control module can develope a crack that that only opens at operating temp. Hence the random code 42 showing. If it was toast, it would throw the code all the time. Same thing used to happen on the HEIM. Only it was on the pickup. Also check your connections at the ignition module. Maybe a corroded connector. A good cleaning and die-electric grease might solve it.
    • Crimson Fury
      dropped your pocket
      • 111
      wheres the module located?
      Car Domain site!
        • 13534
        When my knock sensor went stupid, it would give me that code sometimes as well. I think it was from water or something cause it went away a month later (when i turned the code back on the ECM, it didnt come back when i put it back on).
        • Crimson Fury
          dropped your pocket
          • 111
          got it diagnosed as the ICM(ignition control module). for the stalling and crappy starting, dirty throttle body. they quoted $360 something for it all. $165 for the ICM alone, nah! autozone's $80 sits better w/me
          Car Domain site!
          • Crimson Fury
            dropped your pocket
            • 111
            it was the ICM and it is fixed. don't wait to replace the icm when code 42 shows up, cause it'll kick you in the nuts and walk all over you!
            Car Domain site!
