fuel pump upgrade
  • tony94gtp
    • Jan 2005
    • 34
    fuel pump upgrade
    i having a fuel pump problem i installed and aftermarket pump from auto zone u know its made in mexico, anyway i think the check valve is defective in the pump. it will not hold pressure when engine is shut off. thats the only thing it could be. so i was thinking of getting and acdelco pump from the dealer or upgrading to stronger pump like walbro 255 lbs/hr would this be a good idea or would it be too much for a tired stock engine whith 188,000 miles on it? the dealer pump is about 145.00 dollars and i think the walbro pump is cheaper. and if its not going to hurt anything where could i get a walbro pump local instead ofgetting one online?. iam in the baltimore area . any help or suggestion? thanks tony94gtp
  • Kohburn
    custom fab-whore
    • Apr 2005
    • 165
    usually not holding pressure is a sign of a leaking injector or a bad fuel pressure regulator - I have a walbro pumping to my dohc (but then again i have turbo plans)
    • Kohburn
      custom fab-whore
      • Apr 2005
      • 165
      just saw your other thread
      Originally posted by tony94gtp
      i posted a couple days ago with this problem. i since ckeck the pressure with key turn on pressure is a 40psi but then drops to 0 after pump stop running. i changed the regulator for the sake of it . i cant seem to find any leaks anywhere. i was hoping the regulator would have fixed this problem to keep from droping the tank again i was reading in my hyanes manual to check the in tank fuel pump check valve. where is is this check valve located in the fuel pump because i didnt see one when i was taking the old pump out nor did i see one with the new pump. can i get some help please
      its also possibly a leak in the connection between the fuel pump and the high pressure line inside the tank..
      hows your car starting when hot? milage good? I'm still suspicious of a fuel injector
      • tony94gtp
        • Jan 2005
        • 34
        the car runs fine it wont start right away after its been sitting i have to prime the fuel rail by turning the key on then off to on to so start thats about it. iam thinking the pump i just installed is defective like the ckeck valve. i would think that i would be blowing alot of white smoke and the smell of gas from the exhaust if and injector was leaking the car was running fine until the fuel pump went up and i installed one from advance auto parts ran for two days good start up and was good then the start up problem began.
          • 13520
          I run the walbro (holley) 255 lph and its fine. I ran it with my 3.1 and now my DOHC. I would go with that over the AC delco stock replacement pump. I have no idea on the check valve, as ive never really looked at the fuel pump. If its dropping pressure that quickly, you would definetly notice something while driving if it were the injectors leaking.
