What could be wrong?
  • Kyles93Z34
    • Dec 2004
    • 347
    All right, i have a 93 Lumina Z34 that for the past 4 weeks has been giving me a lot of pains with things going wrong left and right. I have been posting on this link for most of the time but i am not getting a lot of help there so i was wondering if yall could help me.
    Any thoughts would help. Thanks
    Kyle
    1992 Lumina Z34
    5 Speed
    Autozone civic intake
    Ultra White lights
    FFP Dogbone mount
    125k miles
    2.5 inch Magnaflow catback from Magnaflow cat
    60degreeV6.com Custom Chip
  • Kyles93Z34
    • Dec 2004
    • 347
    I just noticed that i put it in the wrong section. Sorry, i just always go to performance.
    Kyle
    1992 Lumina Z34
    5 Speed
    Ultra White lights
    FFP Dogbone mount
    125k miles
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      could be a vac leak. a big one, check your pcv connections. or your maf but that would get u a ses light.
      EDIT: shit that's right a 93 no maf dooh.
        • 13533
        Check the MAP sensor lines. There should be 3 going to it. Sounds like a vacuum leak somewhere and the MAP sensor doesn't like the reading.
        • Juglenaut
          • 1130
          It is a performance issue so don't kick yourself.
          Well checking for fuel pressure, replacing the fuel filter, and testing the fuel regulator. Also could be an ICM/per coil problem. Sadly it may also be a syptom of a bad fuel pump, but check less expensive (also easier to replace in most cases) fuel and ignition system components first.
          As it is starting harsh and stalling predictably, a MAP fault code would be stored if it is the problem.
          I am back
          Mechanical/Service Technican
          • Kyles93Z34
            • Dec 2004
            • 347
            This is getting weird. It has cranked up perfectly the past 2 days, but on 1 condition. The a/c has to be on. With out the a/c on it will die 2 seconds after i start it. Thanks for the help i will try to get to it sometime this week.
            Kyle
            1992 Lumina Z34
            5 Speed
            Ultra White lights
            FFP Dogbone mount
            125k miles
            • pepsi_coke
              • 288
              The A/C raises the idle
              New member of 200,000 mile club as of May 16, 2005
