Anybody manage to take the engine and trans out the top before? Is it even possible?
3.4 + 284 out the top
I did it but I had to pull the resevoir part of the brakes out as well.Ben
Ben's black car also didn't have heads on the engine either when I helped him pull the engine and tranny out.-60v6's 2nd Jon M.
I've pulled the engine and tranny together out the top before...no ABS, though, and still had to take the master cylinder off the booster. Even with this it was tight...the crank pully was rubbing on the right inner fender while the tranny was rubbing on the AC lines.
I pulled mine together out the top, no manifolds on and every accessory was off the motor. It was tough, we had to angle the motor to get it out, but we got it. The hardest part is getting the driver's side of the 284 to clear the bird nest of crap on the driver's side of the compartment.
