timing belt broke
  • rslayerr
    • 31
    timing belt broke
    heya all..well..my damn timing belt broke,well actually,didnt broke,but lost all the "teeth"so its still there but no longer rotate..i have a 91 3.4 dohc engine...
    i think it broke in the 4000 rpm range..
    how much risk that my head are damaged??
    what would be my best solution right now..i wonder what i should do..only replace the belt and hope that everything is ok...or well im at it..change the engine completly.(maybe a 96-97 one???)how much trouble i could have by swapping it??
    im damn confused to what i should attempt...paying big shit for a 210 000 km engine with a broke belt..or go for the big thing and change it all...damn thing
    any advice,help greatly appreciated..tks to all
    grandpa car with attitude!
    3.4 tdc
    205 000 km
    mtl.qc
  • pepsi_coke
    • 288
    Well, there is some good news. GM made your engine to be a non-interference motor. I have a 92 (now has over 200k) and the timing belt broke 2x on highway speeds during the course of driving.
    However, there is always a chance you snapped a valve .. or a whole row ..
    If it was me, I would install a new timing belt and go from there.
    About the swap .. the 96-97 will require some modifications to work. It has been done many times though. But if you were to go that far as to do a swap, while not do a basic rebuild to your current existing block that came with your car?
    If your upto, why not remove the heads and take them to a machine shop to check them out.
    Good luck,
    -Jay
    New member of 200,000 mile club as of May 16, 2005
    • rslayerr
      • 31
      tks pepsi for the reply...dammit hopefully i didnt broke a row of valve.
      3.4 tdc
      205 000 km
      mtl.qc
      • rslayerr
        • 31
        1 question i have touhg,since i have to remove intake and valve cover..do i have to replace the gaskets,or they are re usable??
        tks
        3.4 tdc
        205 000 km
        mtl.qc
        • pepsi_coke
          • 288
          Replace all gaskets.
          • rslayerr
            • 31
            tks alot pepsi for fast reply...
            i have call a couple of place and i can do a complete rebuilt of the engine for 3000$...you think its worth it.?good price??
            brand new engine should put back a lot of lost power...
            3.4 tdc
            205 000 km
            mtl.qc
            • clevo
              • May 2004
              • 32
              $3000 for a complete rebuild. The (dealer) mechanic quoted me just about $2000 for just a timing belt and distributor o-ring fix.
              1995 Cutlass Supreme
              3.4 dohc
              • rslayerr
                • 31
                yah well..i have check with the dealer for changing my timing belt..and just for the parts,i is like 700$
                170 timing belt
                218 tensionner pulley
                83 idler pulley
                163 for intake gasket
                60 for valve cover gasket
                they are completly nuts...i have found all those thing for less than 250$ at other place...so fck dealer..they are theft dammit..so 2000 for yur stuff..i have no problem imagining it.
                and for fun..i have the dealer for a kit to rebuilt myself my engine...so he said"well..its all seperated part..i have to make a list and call you back.",i said ok...
                30 minutes later,the guy call me and said"well..im not even finish looking up for the parts,and im at 7000$ right now"
                well,do i have to say that this is ridiculous!!!
                i have laugh soo hard..
                anyways..dealer are moron!!
                hehehehe
                3.4 tdc
                205 000 km
                mtl.qc
                  • 13525
                  Don't go to the dealer, simple as that:P The heads are probably fine, with good enough odds that I would just put a new belt, idlers, tensioner, and tensioner pulley in it and time it. That is money well spent cause even if the motor is fucked, you can pull them for another motor (though no 96-97). I personally wouldn't use a 96 motor in an automatic but there are plenty of others that have done it so they might disagree with me.
