Where else can I be losing this much oil?
  • DrRodey
    • Nov 2004
    • 76
    I've looked extensively over everythign for external leaks. NONE, checked camtowers, heads, intakes, mains, even the infamous o-ring is dry. It's not smoking and the exhause smells normal. But I'm still losing about a quard a week somewhere. What else can I check? I'm out of ideas. Thanks
    Dan.
    92 GP GTP 3.4DOHC 5spd
    88 Fiero Formula CONVERTIBLE 3.4DOHC 5spd
    84 Fiero T-Top 3.4DOHC 5spd
    There seems to be a pattern there.
  • pepsi_coke
    • 288
    Rings? PCV valve?
    New member of 200,000 mile club as of May 16, 2005
    • DrRodey
      • Nov 2004
      • 76
      With bad rings, wouldn't it be smoking at least a little though? Hope it's now since the engine was just rebuilt about 40k ago.
      Any other Ideas? Keep them coming...Thanks
        • 13525
        Its the PCV, id almost bet a lot of money on it cause its very popular. Even with a new one mine likes to eat it sometimes. I think its slowed down on my car, once I taped up the rear cam carrier PCV setup cause it was cracked. Other than a catch can, I don't really know what to say for fixing it. The catch can is going to be what I do eventually...if people stop hitting my car in parking lots anyway!
        • 5speedz34
          • 301
          Shit when did that happen!
          Do you have any explanation why are cars suck so much oil through the PCV?
            • 13525
            Has to be crankcase pressure or engine vacuum sucking the oil up through the PCV lines.
            I was in the parking lot of advance auto pulling in. Saw a guy with a rodeo or 4 runner or something, kinda in a space. Then, as im behind him, he starts backing up, so I get on it a little and he tags my passenger side light and the metal right before it. I just need a light, paint, and buffing,as I have pushed it back out for the most part. Poor car:P
            • 5speedz34
              • 301
              Yeah, our motors make alot fucking vacuum. You would think GM would hire better engineers.
              • JasonZ34
                • 116
                Shit union engineers are expensive
                • blk92z34getrag
                  • 515
                  Not to mention the engineering in our engines is about 15 years old. I mean, people were playing DOS text-adventure games and still thought they were technologically advanced.
                  --Rob
                  • wdowey
                    • Nov 2003
                    • 16
                    oil leak
                    it could be plug under the rear head on the block where the distributor use to be....thats what was wrong with my 95 ..it fucked with me for a year
                    • DrRodey
                      • Nov 2004
                      • 76
                      *Update*
                      Pulled the pcv, there was a little (very little) oil residue so that could probably be where it is all going. I"m working on a couple different "catch can" ideas of my own so we'll see what happens.
                      The leak has slowed down though too for some reason. Havne't had to add oil in almost two weeks but i'm not holding my breath yet.
                      Guess you didn't fully read my first post. I had already check that... dry as a bone. Thankfully. Thanks for the help though
                      Dan.[/quote]
                      • Kohburn
                        custom fab-whore
                        • Apr 2005
                        • 165
                        someone mentioned before that the lifter valley cover can crack underneith and force oil up through the pcv
                        something i have planned to look into if i ever pull the lower intake
                        • denial
                          • May 2005
                          • 9
                          Dr.-
                          Check my post not far below yours. It's called "oil consumption-problem solved." I was burning a quart every 100 miles. It was the gasket under the oil distribution plate. This is the "lifter valley cover" that Kohburn is talking about. Not too tough to change. Hope this helps.
                          Denial
                            • 13525
                            From the depths of hell, a thread is reborn!
