verify this picture for me
  • Jazic3.4
    • May 2005
    • 29
    This is the engine compartment of a 1992 Lumina 3.4DOHC. looking at the arrow, is what I'm pointing to the Vapor canister?
    I'm trying to hook up the vaccuum lines for the cannistor purge solenoid valve. If this is not the canister, please point it out for me.
    thanks
    • 13510
    RE: verify this picture for me
    Its in the back of the car...
    The lines you need to hook up are on the engine, passnger side, where the plenum is bolted to the rubber bushing to support it in the rear. 1 of the lines go to the plenum behind the TB, the other to a metal line near the brake booster.
    The aarow points to a drain for the AC i believe. Its a drain point, dont hook anything up to it.
    • Kevwood
      • May 2004
      • 122
      Ben, you are correct sir...
      That is the AC condensation drain. I removed the firewall liner when I did my engine swap and forgot about what it was for a while, just a rubber nipple.
      The line that goes back to the vapor can is in with the brake lines. It blends in with them rising up at a 45* angle then leveling out. It's the only line that doesn't go to the ABS brake manifold.
      Z34 red, auto, written of by a red light runner.
      Z34 white, 5 speed, stored in Canada
      Mercedes-Benz C20K, Dubai
      Mercedes-Benz CLK500 AMG, Dubai
      • Jazic3.4
        • May 2005
        • 29
        Can any of you point out the line in this new attachment that goes to the vapor can? If you can, please show me with an arrow.
        thanks guys
