Most Difficult Proceedure for You
  • napatiger
    • 490
    Just like it says, if you add in reply I will add options.
    Maybe we can turn this into a "tips" thread.
    For me right now the most difficult is the wiring harness
    It is so ridgid and must be routed so damn perfectly and the proceedure usually involves getting your hands into places you can't see.
    2
    Alternator
    50.00%
    1
    Wiring Harness
    0.00%
    0
    Spark Plugs and Wires
    0.00%
    0
    Steering
    0.00%
    0
    Upper Air Manifold
    0.00%
    0
    Bottom end (Crank, Bearings, Ect)
    0.00%
    0
    Timing
    50.00%
    1
    Timing Chain
    0.00%
    0
    Brakes / Suspension
    0.00%
    0
    It is hard for me to change the oil
    0.00%
    0
    95 MC Z34 Black
    • 13534
    RE: Most Difficult Proceedure for You
    I dunno, probably the bottom end cause you gotta pull the motor out to do any of that. Power steering lines are up there cause its a pain to route the return line.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      ya i voted for bottom end.
      • napatiger
        • 490
        I figure that removal of the engine is a process and bottom end a different process.
        Bottom end is hard b/c I don't have the torque angle thingey, but once the engine was disassembled to that point it wasn't that hard.
        I just found out tonight that the rear strut and springs are a cake walk to replace.
        Still trying to find out why I don't have spark.....Damn electical.
        O2 sensor is a bitch to change with engine in car.
        95 MC Z34 Black
        • z34phoenix
          • Jun 2005
          • 469
          I dont know gassing her up is getting difficult with these prices!
          • Juglenaut
            • 1130
            Try and replace the heater core water return line...That one that goes all the way around about half the engine to the water pump. That is a pain. The most fustrating this to me was that spring clamp, it came off with struggle but the hose was super bonded to the connection. The o2 is cake to that.
            Alts arn't a walk in the park with bottom mount, but I rather do that over the water line. Plus replacing the alt gives you a list of things that you can replace if they are worn.
            I choose bottom end, to me it was a endless fustrating mess from he11, but oddly enjoyed it.
            I am back
            Mechanical/Service Technican
            • dohcfiend
              King Chalupa
              • Jan 2004
              • 2351
              oh ya, i remember when i had to replace those cv boot bandclamps. omg never again, i'll just pull the axels out and let tranny fluid go everywhere.
                • 13534
                That coolant line is a breeze with the cam carrier off:P You can then take off the alt pretty easily. Sure, not everyone wants to do that for a stupid line but hell, it still beats pulling the motor!
                • Lyle's GTP
                  • Jan 2004
                  • 1345
                  Ditto
                  Lyle
                  • slick94prix
                    • Jan 2005
                    • 201
                    Alternator- 45 minutes
                    Wire Harness- Did it in a day
                    Plugs and Wires- 30 minutes
                    Steering- Never messed with
                    Upper Intake manifold- 15 minutes and it's off
                    Bottom End- Never messed with
                    Timing- Haven't had the pleasure of messing with yet
                    Timing Chain/Belt- See above
                    Brakes/Suspension- Easy stuff
                    Oil- This is a joke, right?
                    1992 Miata B Package
                    1995 Regal 3100
                    1996 Firebird LT1 T56
                    • spacecadetz26
                      • Nov 2004
                      • 119
                      I think the hardest part is paying for the parts, everything else is easy.
                      Stephanie
                      92 GTZ ~SupermoddedW41GTZ~
                      • OldSkoolGP
                        That guy over there
                        • 930
                        Considering I can pull my whole drivetrain in 90 minutes, I'm not voting for bottom end. Though I may want to write in Crank Position Sensor at the moment. Automatic transmissions suck!
                        • slick94prix
                          • Jan 2005
                          • 201
                          Small hands fix that problem.
                          1995 Regal 3100
                          • OldSkoolGP
                            That guy over there
                            • 930
                            Indeed. Can I borrow yours?
                            • Juglenaut
                              • 1130
                              I can re-wire color for color re-pin and re-loom just about any factory harness in a day, it all depends on if I have the pins and wire color or not.
                              I am back
