Gear Tool
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Gear Tool
    Is there a special puller used to remove the oil pump drive cog? Not enough clearance to use my standard puller. I could make one I guess. Just a PITA though.
    Or is there a trick?
    • 13525
    It uses a speciall puller...same one actually as the 91-93 cam gear puller. It has 3 self tapping bolts that go in those holes you see. Then it can pull it out. I have the tool but I am missing one of the bolts because jon decided it would be great to lose one:P He doesn't read this so I can talk some shit
    You could probably get another bolt that is the same thread pitch and use one of the remaining 2 to pre tap it. Let me know if you want to borrow it.
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      I'll just tap the thing to 7/16-20. I just thought there might be a trick I didn't know. Thanx..
      Now get busy on my heads.... jk, I'm in no hurry.
