IS there a 95 3.4 chip on its way?
  • 95cutlassconvert
    95cutlassconvert
    • Jun 2006
    • 1
    Hi: I'm brand new to this site,although I have been reading it for some time. Word is that you guys are working on a 95 LQ1 chip. Fact of Fiction? Although I am abosultely new at this, reading your site has convinced me to wait for you, rather than buy some generic product.
    Please let me know when and if.
    Thanks.
    1995 cutlass supreme 3.4L
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    There is no "Generic" product for 94-95s. There is a chip being worked on by Ben. Probably different versions depending on your modifications. Be patient and it will come about. He won't let go of something that doesn't work.
      • 13522
      My test vehicle has been stubborn. Ive torn the top of the motor off 3 times now and although it does run good finally...it leaks a quart of oil in a mile. So apart it goes again. Im going to work on it some later today and hopefully finish it up by next weekend pending that it is a cam carrier gasket or something along those lines. It didnt leak before this last tear down and I think I scraped the carrier against that gasket causing this to happen.
      Its almost done though but I want to put it on the dyno and finish it up along with setting up the shift points better than stock. After that, ill have a chip done for stock cam timing. Other timings will come after that.
