Custom made fuel connectors
  • d.o.h.c
    • Jun 2004
    • 981
    I made these connectors, take a look. I took the old hose off the stock connectos and cut the ends off. I then ordered special -4an weld on fittings and am having it welded at my machine shop. I think the braided ss line will do better with the turbo and wount break down. It you want some made PM me.
  • series8217
    • Dec 2004
    • 387
    They are undersized especially for a turbo.
    The stock fuel lines are 3/8" (-6 AN) for the feed and 5/16" (-5 AN) for the return.
    I would have made them both -6 AN.
    • d.o.h.c
      • Jun 2004
      • 981
      Good point. What I am going to do is make the return a -4an and the feed a -6an. thanks. Good thing they arent welded yet
        • 13530
        They make fittings you can use right on your stock line by cutting and using a compression fitting. Earl's is one brand, but there are some less expensive anodized fittings available.
        • d.o.h.c
          • Jun 2004
          • 981
          Shoot a pic up please. The stock fuel connectors are that special connector that snaps into place. I just ordered the 6an fittings and am returning the 4an lines for 6an.
          • d.o.h.c
            • Jun 2004
            • 981
            You mean something like this
            ANplumbing.com Largest online supplier of XRP & Earls AN Fittings. Search our huge inventory of AN Adapters, AN Hose Ends, AN Hose, and accessories for racing, marine, and aerospace applications.
            • d.o.h.c
              • Jun 2004
              • 981
              I just returned the lines and am getting both -6an. Thanks for the help.
              • RedZMonte
                • Feb 2004
                • 1378
                I took the stock connector and had a new hose added and crimped on using a compression fitting.
                gotta be carefull too, i think there are small o-rings inside the stock connector that keep it from leaking. so don't cut them off and don't melt them when you weld it.
                S
                Shane "RedZMonte"
                1992 Lumina Z34-VIRGIN (RIP)
                1992 L67 Lumina Z34 (SOLD)
                1990 Turbo Grand Prix (SOLD)
                  AN compression fittings.
                  The T is for my nitrous solenoid feed.
                  It's a shame that my steel braided lines leaked fuel... It like soaked through them for some reason. I'm thinking I didn't assemble them properly.
                  I need to remake them or buy premade ones
                  • d.o.h.c
                    • Jun 2004
                    • 981
                    Yeah, I replaced the o rings. they are very hard to replace.
                    • Identity Crisis
                      Lost at Birth
                      • Jul 2006
                      • 295
                      Thats what I want to do on the GTP
                      I dont know what this means but "ASS HATS" is funny
                      • series8217
                        • Dec 2004
                        • 387
                        Just don't collapse your feed line like the one in the second pic that was poorly bent.. thats not going to flow too well.
                          Um, those are all factory bends... I'm not worried.
                          • ryan.hess
                            • 526
                            Summit sells the quick release adapters for AN fittings:
                            Part #'s
                            RUS-640850
                            RUS-640860
                            Okay now, that's enough of that.
                            • series8217
                              • Dec 2004
                              • 387
                              I've never seen a factory bend where the pipe was crushed like this. That is definitely a restriction to flow. No point in having a -6 pipe when your bends reduce it to -4.. You should probably cut it back and rebend it or make a new line.
