poly front control arm bushing?
  • latemodelnewbee
    • Jun 2007
    • 227
    i want to rebuild my front suspension but don't want to use stock rubber bushings and i can't find any poly bushings for my front control arms. I was wondering if any body makes poly front control arm bushing for my 91 z34. who, what, and where
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
  • choppester
    • Mar 2006
    • 57
    you need to goto autozone ask for energy bushing book and they should have it in there I can look up where I got mine but its soo long ago I did that and I have to go through alot
    • OldSkoolGP
      That guy over there
      • 930
      If ES (Energy Suspension) has a part number for the factory W-body bushings, please post it. We've always had to measure the factory components and uses universal bushings that fit on the rest of the car.
      • HayesPerformance
        • 783
        They don't make them for the Gen I W-body. You have to measure and use universal ones.
        I have ALL the aftermarket performance catalogs.
        There are a few Poly bushing companys but none currently make them specially for the GM W-body Gen I
        1991 Grand Prix STE
        3.4 DOHC
        1 of 792 Produced
        Extensive Mods Done
        1991 Lumina Z34
        3.4 DOHC
        Getrag 284 5spd
        1 of 30
        • choppester
          • Mar 2006
          • 57
          that not what i meant
          no they don't have listings for the w body but there are some after market ones that have been used I also do have the books and if you live in south eastern of wisconsin that be better cause I can help you out alot
          • latemodelnewbee
            • Jun 2007
            • 227
            PST wanted to sell me a bushing set for 89-96 beretta which is screwed up cause the rear lower control bushing changed from a horizonal to a vertical in lick 92-93.
            i'm probally just going to chuck some poly leaf spring bushings in my lathe and turn them and press them into shells. i did it for my buddies 64 rambler american with SBC, on the front suspension and the motor mount and they work great
              • 13533
              Where do you get the shells? That is what stopped me from making any because I want to have a metal sleeve for them.
              • latemodelnewbee
                • Jun 2007
                • 227
                i'm just going to get some control arms from the junkyard and instead of pressing the original bushings out, i'm going pull out the tube for the bolt to go through and then hog out the rubber and turn down some leaf spring shackle bushings till they fit tight and use a poly based liquid nails to make sure that they won't move. no press or machine shop required, ya
                • Schurkey
                  • Apr 2007
                  • 339
                  A propane torch will pop the rubber bushings out of the steel shells very nicely. They practically jump out once you warm the shell a bit. I've done this on several Olds Toronados and older GM "A" bodies. You will need to clean some rubber residue out of the shells, I use emery cloth. If you get new inner sleeves with the bushings; fine. Otherwise I make new ones out of steel tubing. You could re-use the old ones if they're in good condition--but all the ones I see are corroded.
                  Why glue the bushings in? One of their best features is that they rotate in the shells; which means you DON'T have to have the suspension at normal ride height before torquing the bolts that go thru the bushings like you do with rubber bushings.
                  Use high-quality grease on the INSIDE and the OUTSIDE of the poly bushing or they can squeek. The supplier of the bushings will have a suitable lube; I'd expect 'em to include a couple of tubes with the bushings.
