Disappointing....
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    Disappointing....
    This is going in the performance section due to the lack there of....
    Going to work yesterday in my '96 Z-34 Monte, and a 93 SC2 saturn pulls up along side at a light, he's gold with a black fender and primer on his front clip in various places, kid driver. Light went green and I decked it, the tires barked and I'm thinking saturn no problem, the kid next to me realized what was going on, didn't break his tires free, but I think i did hear a slight spooling sound, might have just been the motor. I put a fender on him when he hit 2nd and barked the hell out of his tires, he then proceeded to put a fender on me. I hit 2nd and lost another foot on him he hit 3rd, got rubber again and jumped to half car length, we held there till his gear change came up again, he hit 4th and got rubber AGAIN!, and pulled another few feet on me putting him about a 1/4 car legth in front, I got 3rd and lost some more footage. I came off the gas at 100 and watched him disappear.
    I remember the 92 lumina Z-34 being faster than this... Or maybe I just dont remember what she was really like before the mods. Or, are these things really this pathetic?
  • 1988GTU
    LB62LHObbqftmfw
    • Nov 2005
    • 2475
    You have been had by a sleeper.. They'll do it to ya.
    • 95SleeperAcheiva
      • Jun 2006
      • 694
      This is BS! I cant wait for my V-8 Achieva to be done!
      • z34phoenix
        • Jun 2005
        • 469
        V8? i think just some good mods and tuning on your 96 Z and you should be golden!
        • 95SleeperAcheiva
          • Jun 2006
          • 694
          I bought the Z as a work car till my Achieva is done. I'm currently wedging in a 4.0L aurora V-8 with a 282 behind her. Chrfab is helping with it. I have already pick up pistons from aries, assembled a rebuild kit, and I will soon order cams from them, port and polish work the heads through them, only cause they are familiar with the motor, and a ecu system from them programmed for that motor.
          They aint a bad company to work with, so far, they haven't returned emails as fast as i would like but, maybe they busy.
          Which brings me to getting the stock intake flow tested so I can look into proper cams for it. Which brings me to Ben for flow testing the intake. I'll have him do the heads to if he thinks he can tune them without having to go through more than 1 set :P
            • 13531
            I need to redo the flowbench before I can do different heads.
            • OldSkoolGP
              That guy over there
              • 930
              Also remember Saturns are made of plastic so they're pretty light, which helps.
              • patgizz
                The Plaid Bandit
                • 1071
                the beauty of a sleeper. nobody thinks anything of my 4 door belair with faded/peely paint and rust spots, until it beats the hell out of them.
                  Heh, you can bark tires with a manual with even low power if you shift it right. I was barking 4th with a 2.5L iron duke grand am before
                  • kyobukan
                    5 SPD Z34
                    • Jul 2007
                    • 73
                    Pathetic is the key word my bro.
                    sadly My 1991 Z34 5 speed prolly could not take my wifes 2003 Chevy Tracker V6
                    I have had the Lumina only 4 months and already think it is a POS.
                    When is the Z28 coming back?
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      You probably need to stop ragging on it and fix all whats broken and bring it back up to spec. That engine is no toy that comes in todays saturns, AND you have a 5 speed? Geesh it should be that much quicker. There's something wrong.
                      • latemodelnewbee
                        • Jun 2007
                        • 227
                        There is one hell of a sleeper here San Antonio, TX. It's a mid 90's cavi thats all faded primer gray, hubcapless steelies but it has 383, powerglide, ford 9".
                        You couldn't tell when it was parked and still difficult when it was running, it has HUGE mufflers all you hear from the pipes is air moving
                        68 El camino 454 speed muncie 3.90 posi 12 bolt,
                        80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
                        60 Impala 2 door hardtop L79-327 T56 4.11 posi.
                        83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
                        91 Z34 now has a hm284. and belly pan in the works
                        • kyobukan
                          5 SPD Z34
                          • Jul 2007
                          • 73
                          Been fixing it for 4 months now.
                          You want to buy it?
                          I'm more old school V8 kind of guy but I still bet I can't out run the V6 Tracker
                          • 1988GTU
                            LB62LHObbqftmfw
                            • Nov 2005
                            • 2475
                            You want to buy it?
                            HELL no I dont want to buy that. lol I have my own PITA cars to work on!
                            Someone that does buy that car would probably just part it out (trans, some little pieces) so the value is not worth much.
                            • kyobukan
                              5 SPD Z34
                              • Jul 2007
                              • 73
                              LOL
                              so far we put a cat converter, plugs, wires, brake work, power steering hoses, alternator, tie rod, battery.
                              I think it might have to go to the Chevy dealership for some fine tuning.
