Looking for .20 over Pistons and Rings..
  • fathead45
    • 73
    If you have any info on where i can get some please let me know.
    thanks.
    1st 04 GPG 88-96 mod car show
    L67 Swap, 3.25, XP'd, Custom Headers, 180 tstat, AL103's, 7" K+N, AFC2.2, Rat UDWP & Alt, Walbro,Taylor wires
    N* TB & HP Ported Blower
    PB-13.3@102mph
    http://www.SleeperSe.com
    http://wbodysource.com
    • 13531
    I should have a set of rings soon, .020 over from GM.
    • fathead45
      • 73
      will i have to get bigger pistons or would it be safe to just use the .20 piston rings??
      how much??
      any word on the TB??
      PB-13.3@102mph
      • Cotton
        • Feb 2004
        • 33
        you have to have the proper clearance between the piston and the cylinder wall, these clearances are piston specific.
        The machine shop that i used obtained pistons for me. Speed-Pro #SIL3409+20.
        the rings are Hastings HAS2M4649+20.
        If possible, the machine shop should want to check the block first to determine the amount of over bore it will take to "true up" the cylinders. Then, obtain the replacement pistons, measure each one, and bore each cylinder to match a piston, this way you get the best fit for each cylinder.
        proud supporter of \"W\"
          • 13531
          Running stock pistons with oversized rings is not gonna work out too well. You should definetly have the block checked out and have it bored to what is needed first. If you get the .020" over parts now and the shop has to go larger, it will be a waste.
          Only news on the TB is that the plates weren't done, they were only 65mm, not 69. Im still looking.
          • fathead45
            • 73
            ok, thanks for the heads up guys.
            thanks for the update on the TB. I will try to find a machine shop.
            PB-13.3@102mph
