retard timing ?
  • Mitch DOHC
    • Jan 2004
    • 261
    i have a high stall converter in my auto... so im not really expecting any hit to the low end
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
    • canusa
      • Jan 2004
      • 32
      ok well i have to work crazy hours over the next couple of days .. but so far everything seems to be in order i just need to put the rest of this beast back together.. and then i can start it yay !!
      -canusa
      -Canusa
      91 GTP 5 Speed (Retired)
      15.1@92MPH Bone Stock
      • dykz34
        • Jan 2004
        • 793
        Ben, weren't you telling me how you fucked up on the measurements and that your "13" is actually closer to 10?
          • 13531
          Hmmm, ill have to measure it again with that block on the stand. I actually forgot all about that.
          • canusa
            • Jan 2004
            • 32
            ummmmm yea... if that was only 10 degrees i'm gonna do it over to get 13. let us know when you measure it please
            -canusa
            -Canusa
            • Mitch DOHC
              • Jan 2004
              • 261
              #21
              how about this i went out to look at doing the timing and the way it was timed up to start with was that the exhast cam is advanced about 3 degrees from the intake cam.... shouldent both to the cam flats be facing up together... that is the way i under stood it>>>
              1969 Oldsmobile 442
              1997 Chevy Tahoe
              • canusa
                • Jan 2004
                • 32
                #22
                -Canusa
                  • 13531
                  #23
                  Ok, I measured AND took pics so this wont confuse anyone. I told a few people a while back the mark I was using wasn't really 13, it was 10. I thought it was 13 but it wasn't. That ridge on the timing chain cover is wider than 1 degree, and we were trying to measure with the engine in the car. I have a cover and the part with the mark on it off the car.
                  Stock
                  10 Degree Mark
                  13 Degree Mark
                  • canusa
                    • Jan 2004
                    • 32
                    #24
                    ok and the 10 degree mark is the one that is most beneficial to us without creating knock and stuff right
                    -Canusa
                      • 13531
                      #25
                      Nah, going past the real 13 mark is where it gets bad. I thought the real 13 was a bit further. What I had tried was closer to 18. 10 is good for sure, cause that is what I did all the testing with. 13 is something ill try when the car is running again so I know for sure. I think it may be at that anyway since I wanted to go a hair more than I used to. Seems ok if thats the case.
                      • Mitch DOHC
                        • Jan 2004
                        • 261
                        #26
                        so at the stock mark the back cams should be up and the front down... or is it the other way around
                        1969 Oldsmobile 442
                        1997 Chevy Tahoe
                          • 13531
                          #27
                          either way, each bank is 180 the other bank.
                          • dykz34
                            • Jan 2004
                            • 793
                            #28
                            So it was basically dependant upon what side of the line you referenced... No biggie, I'm just here to debunk all the myths.
                              • 13531
                              #29
                              You wouldn't have even known if I didnt say anything. Good job perry mason, no donut for you (maybe a kick in the nuts at the meet though. Bout time I started handing those out for this year.
                              • Juglenaut
                                • 1130
                                #30
                                LoL
                                I am back
                                Mechanical/Service Technican
