School me on the 2.6 LY9
  • Frizzle Fry
    • Aug 2008
    • 16
    Ah, OHV. Not sure why I read OHC. I guess I figured OHV was implied these days, unless that's just used as a term to imply non-OHC. Thanks for the input. I think I've been swayed to go with the 3.6 as I had initially thought. I'm sure the milage will be just fine Still curous about the aluminum block usage if anyone knows.
      Mileage with DOHC always seems to be little lower than pushrod. I'm not sure if that's due to extra weight with the valve train, or that they make torque higher up in the RPM range so you are turning higher RPM or both. But as far as having a more powerful motor, as long as the car is lightweight you sometimes GAIN mpg.
        • 9190
        Yes, the 2.8/3.6 DOHC engines are the only 60V6 aluminum blocks besides the Bow-Tie block.
          I have a hard time keeping my foot off of it when I drive the 92, so I know exactly why I don't get that good of mpg in it.
          • evilmiata
            • Nov 2003
            • 156
            The 2.6L in the picture appears to be the Cadillac Catera motor or the European version unless it started out as a 2.6L in the Cadi and then was increased to the 3.0L I'm familiar with. It also appears to have the Australian bolt pattern on it which should be the same as that found on the turbo Sunbird motors.
            Not sure how much if any real difference in design there is between the two as a result, but the 2.8L DOHC from the Saab and early Cadi CTS has VVT on intake valves only as opposed to intake and exhaust on the 3.6L.
            Definitely looks like a Catera motor. It's a 54degreeV6; I saw one in the junkyard this weekend and thought "Wow, this would be a cool swap!"...until I did the research. I don't know what kind of bell housing bolt pattern it uses.
            • series8217
              • Dec 2004
              • 387
              #21
              Positive confirmation that its the Catera motor here.
              I've seen a few in the junkyards. It's an Opel V6 IIRC. I haven't heard anything good about them.. haven't heard anything bad either. So who knows. Probably not worth dealing with, really.
