Platinum Plugs
  • GTP091
    • Jun 2005
    • 232
    Platinum Plugs
    I remember there were some threads on here a long time ago about platinum spark plugs being bad for the 3.4 'x' engine. I bought and installed Bosch platinum +4 for my car awhile back; then found posts on here saying bad idea go with oem ACdelco only. Any thoughts on this, or guys with good / bad results??
  • 3100 MPFI
    • 1522
    any BOSCH plugs are going to be bad, but the +2 and +4 are the worst.
    First of all, the spark is going to go the path of least resistance, meaning the spark will always go to the terminal that is closest to the center electrode.
    Also, the GM waste-spark DIS system has a hotter spark than just about any other system, and it will burn the platinum right out of the plugs.
    Generally, when you put the +4's in the car, you MIGHT get 1000 miles out of them, and you will start to get symptoms of a misfire.
    I stick with the AC DELCO rapidfires in 3.1 MPFI, 3100 SFI, and 3.4 DOHC cars.
    Taylor
    1998 Lincoln Mark VIII
    • asylummotorsports
      Banned
      • Oct 2005
      • 649
      Well to begin with you wasted your money on that MSD stuff!
      The ignition systems an our cars are one of the things GM did exceptionally well, and really can't be improved on.
      And MSD doesn't have a great reputation for longevity with MPFI or SFI.
      And a big NO to platinum. Rapid fires are just fine, irridiums for the newer 3500's and such.
      FWIW
      • GTP091
        • Jun 2005
        • 232
        FWIW
        I'm not worried about the money the MSD ignition parts cost I have lots of it. I just wanted to be able to fine tune the ignition and that's something the GM ignition can't do. They wouldn't have made the coil packs if they didn't do something.
        • GTP091
          • Jun 2005
          • 232
          Have you ever had platinums in a 3.4 DOHC or just the delcos?? I know of a few guys on here that put them in their LQ1's and had only good things to say. My car has had a miss since my crank sensor went out and I blew a bunch of money on other things trying to fix the no start problem it caused. I had put in the platinums long before this and they were great. But maybe they have worn out like you said and that's why it misses now. I can't remember what was in my car when I got it in 2001. Do the rapid fires say that on the packaging?? I went in to a store and saw regular delcos and platinum delcos but no rapid fires.
          • 3100 MPFI
            • 1522
            yes, I have used the bosch plugs in a twin cam. When I built the engine in my 1995 I had to drive it with bosch 4's until I could get to the parts store. It was REALLY bad.
            AC DELCO rapidfire plugs for a 1991 TWIN CAM, the part number is 12
            Rapidfire number 12 is what you need.
            Don't listen to what the people at the parts store tell you. When I worked for Pepboys, they would tell us to push the Bosch +4's and when I refused, they started threatening to write me up, and fire me. Also, don't trust the parts store when they tell you the plugs are PRE GAPPED.
            Taylor
              • 13534
              Want to buy an IAT chip, a throttle body heat shield, and a fuel magnetizer? They made them so they must do something. You can't fine tune without computer tuning. Retarding is all the MSD box can do. The coil packs will do nothing that the stock coils weren't doing.
              • geldartb
                The Situation
                • May 2004
                • 1994
                aww man the cats out the bag now there goes the spoiler on my next mods.
                but yeah unless your coil packs go to shit then theres no need to buy aftermarket. the GM ignition on these cars is actually one of the things GM did right.
                as for spark plugs i went with plain ol AC DELCO plugs with my car 2 bucks a plug, and they work just fine.
                even my 2.2 4cyl beretta didnt like the bosch plugs, dont even think they lasted 6 months and very little miles. yeah i made that mistake when i was young.
                99 Grand Am GT
                1357 cam 227 233 .050 dur
                515 515 lift 112 lsa
                  I had nothing but problems with my MSD coils, they burnt up my ICM after a few hundred miles.
                  Rapidfires are platinum, i'd stay away from them as well. Either run the cheap Delco plugs or run the Iridium plugs. iridiums are well worth the money and they last for a LONG time.
                    • 13534
                    When did rapid fire become platinum?
                    • RedZMonte
                      • Feb 2004
                      • 1378
                      I run Plane jane AC Delco's or NGK's... have had nothing but good sucess with them.. +4's are Junk... Gimick... ect..
                      S
                      Shane "RedZMonte"
                      1992 Lumina Z34-VIRGIN (RIP)
                      1992 L67 Lumina Z34 (SOLD)
                      1990 Turbo Grand Prix (SOLD)
                      • GTP091
                        • Jun 2005
                        • 232
                        I bought the Bosch +4's because of research I did on spark plugs. At the time these plugs seemed like the cats ass so I happily paid for them. They certainly didn't say anything about wearing out in a waste spark system. They were advertised as outlasting and outperforming, to bad.
                        I still haven't found the rapid fire plugs at a store yet. I did some research on the AC delco website and it looks like the rapid fires use a platinum pad but the electrode is more conventional. It would seem to me that these plugs would still overheat in a waste spark DIS and end up like the +4 Bosch platinums, with the platinum pad worn away? What do you think? I might just go with regular delcos or the V-Groove NGK's but they seem like more of a gimmick than all of these plugs; I still remember the v-groove commercials.... http://www.acdelco.com/parts/sparkpl...e-platinum.jsp
                          Same link i was about to post.
                          I ran them in a healthy 2.8 Cavalier several years ago, they lasted a month or so. I switched it back to standard Delcos and it lasted for another couple years before a rod started knocking.
                          • mrl390
                            • Jan 2008
                            • 132
                            I was pulling a random misfire code on my car so I changed my plugs. I bought single platinum plugs to replace what I thought were the stock plugs. I ended up pulling double platinums out of the car. There was no evidence that I could see of anyone having done the plugs before, unless they were able to do it without removing the plenum. What DID these cars come with from the factory? When I put in the new single platinum plugs, gapped to .045, I got rid of the random misfire code and the car runs just fine.
                            -Matt
                            • timg
                              • Feb 2004
                              • 718
                              I generally go with Rapid Fires or standard AC Delco plugs. The only problem is that they seem to wear out quickly. Platinum plugs should last longer.
                              Tim
                              325 whp 350 lb-ft
