Cam timing pressure
  • phantomgreen
    • Dec 2006
    • 78
    Cam timing pressure
    I was recently talking to a mechanic about cam timing and he said changes in cam timing changes engine pressure which requires running premium fuel. Is this true?
  • Joseph Upson
    Cam timing can change cylinder pressure however whether or not you need premium fuel depends on how the pressure is affected. That is why high performance cams cause a rough idle, they reduce low rpm cylinder pressure and increase cylinder pressure at higher rpm due to the valve openning and closing point. Once I get my desktop setup I'll try to track down the link to a calculator that demonstrates how the dynamic compression ratio
    differs from the static ratio due to cam changes. The premium fuel requirement depends on a lot more variables than the camshaft itself.
      • 13534
      I can see this in dynomation:P You cannot possibly time the stock cams on a stock compression motor to the point of requiring premium.
      • phantomgreen
        • Dec 2006
        • 78
        Cool thanks for the clarification.
